Old 03-05-2007, 06:13 PM   #541
shocker360's Avatar
Originally Posted by JOHN TAN
Thanks cmain for sharing the tip on this car...may I know one basic knowledge...the tire number higher mean harder or softer?
Higher the shore rating #, the harder the tire compound.
www.vorra.com
shocker360 is offline   Reply With Quote
Old 03-05-2007, 06:14 PM   #542
Trader Rating: 22 (100%+)
Send a message via ICQ to cmain
40 is softer than 42. I would check around the track to see what others are using before buying though.
cmain is offline   Reply With Quote
Old 03-05-2007, 06:26 PM   #543
JOHN TAN's Avatar
Originally Posted by shocker360
John,
Use a pair of small needle nose pliers with the tips small enough to go inside the holes on the clip. Expand them carefully while pulling the bottom of the clip with another small pair of pliers. It's a little tricky, but there really isn't an easy way of doing it. You may want to acquire a couple more spares of those c-clips for future use.
Regards
Hi Shocker,
I was thinking to do that last night...but really need a clamp or 3rd hand...maybe I just replace the whole one way axle with c-ring as my LHS selling them as a set...
JOHN TAN is offline   Reply With Quote
Old 03-05-2007, 06:35 PM   #544
shocker360's Avatar
Originally Posted by cmain
was wondering where you got the Pro conversion kit I also have a RTR and would like to convert it.
Hey c,
I don't know where you can get a conversion kit, you would have to replace a ton of stuff(chassis, fuel tank, upper deck, shock towers, etc..)
But, for $225.90, you can get the pro kit from RC Mart. That's about half the price of any pro kit you will find anywhere! I left a link for you below. Good Luck.
Regards.
http://www.rcmart.com/catalog/produc...ducts_id=15904
www.vorra.com
Old 03-05-2007, 06:39 PM   #545
JOHN TAN's Avatar
Thanks Shocker and cmain...I'm quite forgetful maybe due to not enough sleep...always ask before I buy at the LHS...but now trying to purchase it online...
Oh yes one more thing, is it true the harder the tire will have more traction? more acceleration? but the rear tend to skid when turning? Any tip on that?
Thanks.
Old 03-05-2007, 07:01 PM   #546
shocker360's Avatar
Thanks.
Hi John,
When the temps outside are cooler, I tend on running lower shore #'s (35 or 37), when it's hotter, about 40 to 42. If you are fighting traction issues from the rear, try using a higher shore rating on the front than the rear (37 front/35 rear, for example).
Regards
www.vorra.com
Old 03-05-2007, 07:12 PM   #547
JOHN TAN's Avatar
Hi John,
Regards
Hi Shocker,
So I assume higher # will wear off faster right?
As I saw my rear tire(#40) r wearoff faster while front is (#37) but maybe due to frequent skid. Can I use 40 front while 35 rear?
Regards,
John
Old 03-06-2007, 07:35 PM   #548
shocker360's Avatar
Hi Shocker,
Regards,
John
Hi John,
Actually, the softer tire(lower shore#) should wear faster than the harder tire. But, if you're not getting traction, the frequent skidding would cause the harder tire to wear prematurely. If you don't have matching shore #'s on all four wheels, always use higher shore rated tires on the front. Try using 40 shore front/38 shore rear, or 37 shore front/35 shore rear.
Any one of these suggestions should do the trick.
Regards
www.vorra.com
Old 03-06-2007, 07:39 PM   #549
JOHN TAN's Avatar
Hi John,
Regards
Thanks Shocker
Old 03-06-2007, 11:43 PM   #550
razzor's Avatar
The uneven wear rates is not necessarily shore related it is influenced by how much traction you have on the rear end that would cause wheel spin.
Also overdrive will exagerate this wear.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 03-07-2007, 02:14 AM   #551
JOHN TAN's Avatar
So may I know is there a better solution to solve the traction and overdrive problem?
Old 03-08-2007, 02:13 AM   #552
JOHN TAN's Avatar
by the way any solution to make the hole bigger in the brake disk? As the hole is too small for me to slot in...
Old 03-08-2007, 05:41 AM   #553
for the overdrive you might wanna check the front pulley where the long side belt is connected. they give you the option of using 23 or 24. 23 will make the car more like a front wheel drive whereas the 24 will make the car more 4wd if im not mistaken.
Genius is offline   Reply With Quote
Old 03-08-2007, 05:54 AM   #554
by the way any solution to make the hole in the hot option - brake disk? As the hole is a little to small for me to fix in...
sorry, could you clarify your problem with the brakes again? In any case I was able to install the milled brakes without any problems
Old 03-08-2007, 06:05 AM   #555
JOHN TAN's Avatar
maybe it just my luck as the hole from one of the brake disk too small to slot in to brake disk hub.
Hobao GPX4 Pro grassrootsracer Australia Wanted to Buy 4 06-15-2008 10:49 PM
HoBao GPX4 Pro hooked_on Australia For Sale/Trade 2 12-08-2007 12:54 AM
HoBao GPX4 Pro w/ STS 12 D3R hooked_on Australia For Sale/Trade 0 12-01-2007 01:22 AM
HPI R40 vs Hobao GPX4-PRO ernstb Nitro On-Road 3 02-27-2007 12:16 PM
HOBAO GPX4 hobby racr Singapore R/C Racers 0 12-12-2005 03:58 AM
