Old 02-28-2007, 09:18 PM   #526
shocker360's Avatar
Originally Posted by JOHN TAN
Yes really thanks a lot to explain so logically...I will keep in mind.
What about the gear ratio or is there any combination on both pinion gear 16t /20t and spur gear 43t/47t?
How to choose them? example when using 20t/26t on pinion then can or must use 52/58t on spur gear?
The choice available are:
20/21/22t for the 1st pinion gear
26/27/28t for the 2nd pinion gear
52/53/54t for the 1st spur gear
58/59/60t for the 2nd spur gear
or must within certain gear ratio?
sorry for asking for so much...
No problem, John,
The pinion combination you've listed above is using fine pitch 0.8 gearing, the same that I use. For (1st) spur gear, you can use any 2nd pinion gear, (2nd) spur gear, use any 1st pinion. But the tooth count must match between 1st and 2nd gears. This insures correct alignment and fit of gearing & pinions when the engine is mounted to the chassis. For Example, (1st gear ) 60/20=80, (2nd gear) 54/26=80. Good for small track. Or another example, (1st gear) 58/22=80, (2nd gear) 52/28=80. Good for large track. Also, keep in mind, you can't use 1.0 gearing with 0.8 gearing. the teeth won't match, either too tight or too loose. The previous are only examples. There are no two tracks alike. Experiment and practice on the track you race on, to find what works for you. Race on!
Regards
www.vorra.com
shocker360 is offline   Reply With Quote
Old 02-28-2007, 10:07 PM   #527
JOHN TAN's Avatar
Originally Posted by shocker360
No problem, John,
Regards
Thanks my master I will get the .8 module tomorrow...Will try to run with it this weekend...hopefully the weather is dry...as it been rain for 2 days continuously...
JOHN TAN is offline   Reply With Quote
Old 03-01-2007, 04:27 AM   #528
vc05hdt's Avatar
John Tan, go to thread 0.8 module gear and this will explain about gear teeth split in particular 0.8 module. Shocker is right in theory and I originally asked same question as dumbfounded how some racers at my club having 7 tooth split on pinion gear and 5 tooth split on spur running 0.8 module.
Regards
vc05hdt is offline   Reply With Quote
Old 03-01-2007, 09:44 AM   #529
JOHN TAN's Avatar
I can't wait and bought the 0.8 module but now I had difficulty to remove the pinion gear from the clutch bell... any tool to do this job easily? Thanks.
Old 03-01-2007, 09:55 AM   #530
JOHN TAN's Avatar
Regards
Thanks vc05hdt...do u think I should get extra clutch bell / speed hub / 2 speed clutch ball in order to to save the trouble to remove the pinion gears due to diff track?
Btw is there any tool to remove pilot shaft and fly wheel...
If I had spoiled the head of my screw that secure the engine mount, is there anyway to remove it ? got a suggestion to drill the screw till it broken...any better way to solve it?
Thanks.
Old 03-01-2007, 03:22 PM   #531
vc05hdt's Avatar
Thanks.
I use a long series socket and a special tool from the hobby shop to hold the three prongs on the flywheel whilst untightening the part 22066 (pilot shaft). It might be a good idea to get another clutch bell as there is a 0.8 module pinion spanner you can get but how far do you go?
Old 03-01-2007, 06:57 PM   #532
shocker360's Avatar
Thanks.
John,
If don't have the tools, your best bet is to get an extra clutch bell. In fact, to avoid the headache, I have three clutch bells with three combinations of 0.8 spur gears already on them. And each has it's own bearings.
To remove a striped screw head, I carefully use a Dremel tool with a cutting disk, and cut carefully across the screw head, without marking the chassis, deep enough to then remove the cut screw with a flat head screwdriver. It works for me everytime!
Regards
www.vorra.com
Old 03-01-2007, 08:48 PM   #533
JOHN TAN's Avatar
Hi vc05hdt...Thanks.
Old 03-01-2007, 09:00 PM   #534
JOHN TAN's Avatar
John,
Regards
Thanks shocker...good idea.
Old 03-03-2007, 06:07 AM   #535
JOHN TAN's Avatar
No problem, John,
Regards
Thanks Shocker, I really impress on the speed improve like 25% more on acceleration after using the 0.8 module gear...but i will test more when the new track r ready tomorrow as today the driver stand is under maintenance so I just tried 1 tank to make sure the clutch adjust screw is properly set as I don't have the digital caliber to measure...
Old 03-05-2007, 07:31 AM   #536
JOHN TAN's Avatar
Anyone know how to remove the c-ring from the front one way axle without spoiling it as I need to change the front pulley... ?
Thanks.
Old 03-05-2007, 09:23 AM   #537
Default Set up sheet....
hi people!
I'm new on this site and I have a couple of questions on the GPX4.
I'm actually a electro driver, but a couple of months ago I bought myself a GPX4 RTR just to see if I would like nitro touring and yes I REALLY like it! I have decided that I will only race in this class this coming summer, so last week I orderd the Pro conversion kit for my GPX4 (It will be here tommorrow!) and I got the Team orion WASP REV engine to go with that!
My home track is a large fast track with more then enough grip and I was wondering if anyone would have a nice allround set-up that I can start of with?!?
I hope so because I have got my first clubrace on the 25th of March and I want to get in a lot of practice befor that race!
Dexter83 is offline   Reply With Quote
Old 03-05-2007, 10:10 AM   #538
Trader Rating: 22 (100%+)
Send a message via ICQ to cmain
was wondering where you got the Pro conversion kit I also have a RTR and would like to convert it.
also here is a setup sent to me by a good driver
Front -
45 wt
top of shock all the way in
HPI Blue spring (HPIC
swaybar flat
1 small caster clip in front
1 deg. toe out
one way
2 deg camber
198 mm width
droop 1mm over ride height
Rear -
40 wt
top of shock all the way out
HPI orange spring (HPIC
camber link in top hole on hub carrier
outer hole on bulkhead
stock swaybar
2 deg toe in
100K diff oil
3 deg camber
droop 3-4mm over ride height (adjust for off power turn in)
Tires -
GRP 40 front 42 rear
Body
Parma M type (Protoform Stratus 3.1 works well also)
cmain is offline   Reply With Quote
Old 03-05-2007, 06:02 PM   #539
JOHN TAN's Avatar
Front -
45 wt
swaybar flat
1 deg. toe out
one way
2 deg camber
198 mm width
Rear -
40 wt
stock swaybar
2 deg toe in
100K diff oil
3 deg camber
Tires -
Body
Thanks cmain for sharing the tip on this car...may I know one basic knowledge...the tire number higher mean harder or softer?
Old 03-05-2007, 06:09 PM   #540
shocker360's Avatar
Thanks.
John,
Use a pair of small needle nose pliers with the tips small enough to go inside the holes on the clip. Expand them carefully while pulling the bottom of the clip with another small pair of pliers. It's a little tricky, but there really isn't an easy way of doing it. You may want to acquire a couple more spares of those c-clips for future use.
Regards
www.vorra.com
Hobao GPX4 Pro grassrootsracer Australia Wanted to Buy 4 06-15-2008 10:49 PM
HoBao GPX4 Pro hooked_on Australia For Sale/Trade 2 12-08-2007 12:54 AM
HoBao GPX4 Pro w/ STS 12 D3R hooked_on Australia For Sale/Trade 0 12-01-2007 01:22 AM
HPI R40 vs Hobao GPX4-PRO ernstb Nitro On-Road 3 02-27-2007 12:16 PM
HOBAO GPX4 hobby racr Singapore R/C Racers 0 12-12-2005 03:58 AM
