Old 02-25-2007, 06:31 PM   #496
shocker360's Avatar
Originally Posted by Genius
just as a warning, the front carbon fiber brace on the bumper has a tendency to crack during high impacts. So I use the plastic brace instead and place the carbon fiber on top. This also reduces the flex between the front bulkhead around the diff
Not a bad idea Yar Genius!
www.vorra.com
shocker360 is offline   Reply With Quote
Old 02-26-2007, 12:04 AM   #497
vc05hdt's Avatar
Thanks Shocker
vc05hdt is offline   Reply With Quote
Old 02-26-2007, 12:36 AM   #498
JOHN TAN's Avatar
Originally Posted by vc05hdt
John Tan, what pipe are you running with the Pro car? I can't make out model/part number. Is your pipe/manifold better lower rpm reponse? How about the pinions/spurs? I think mine is 0.8module 16/20pinion and and 60/56 spur. Very neat car.
Thanks, vc05hdt, yes I'm using Team Orion CRF 2626 and these are tuned for high r.p.m. range like what Shocker have stated.
I still using the default 0.8module 16/20pinion and and 43/47 spur...is it to make it faster when using 60/56T?
JOHN TAN is offline   Reply With Quote
Old 02-26-2007, 12:38 AM   #499
JOHN TAN's Avatar
Originally Posted by mac75
Nice car dude
Thanks mac75...u r using the same model too?
Old 02-26-2007, 12:47 AM   #500
JOHN TAN's Avatar
Originally Posted by shocker360
Greetings John & Everyone,
A very nice car! I'm glad you were able to resolve the clutch issue. Definitely pick the brain of the racer who fixed your clutch. Hands on experience is the best way to learn new aspects of your car. I'm glad to read that your engine has improved for you. If you decide later to swap engines, at least by then, your comfort zone and experience driving the GPX4 Pro would make a transition to a faster engine no problem. Now, does your GPX4 Pro out perform your old Cen CT4 ?
Note to vc05: John's pipe is an Orion CRF exhaust, and these are tuned for high r.p.m. range.
Regards
Thanks Shocker, I will change to Nova Engine sooner or later...yet to compare with my old Cen CT4 as I broke my shock shaft and carbon front bumber plate when trying to get 2nd speed...btw I just found that Cen car is using .15 engine... yet to try it out with my new FM radio with powerful servos...sanwa (throttle servo) sx-165t is 0.09sec 9.7kg (steering servo) erg-rz 0.07sec with 8kg. Will change to 3pk when I feel I need more control...
Old 02-26-2007, 12:50 AM   #501
JOHN TAN's Avatar
Actually I broke mine once ...will consider to put the default plastic below my 2nd carbon plate to make it stronger...Thanks for your great idea.
Old 02-26-2007, 02:49 AM   #502
Hello from France,
here's my GPX4 Pro.
My car weighs exactly 1700grs , ready to race (with four little diameter tyres, the body, the personnal transponder, and without fuel).
I like this car.
romuald31 is offline   Reply With Quote
Old 02-26-2007, 03:01 AM   #503
Bundy_Bear's Avatar
Originally Posted by romuald31
Hello from France,
here's my GPX4 Pro.
I like this car.
Hi
What has happened to your Tamyia? And how do you find the belt drive GPX4 compared to the shaft drive?
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 02-26-2007, 05:22 AM   #504
vc05hdt's Avatar
Yes on tight technical track I think with lower top speed and quicker acceleration.
Old 02-26-2007, 05:28 AM   #505
vc05hdt's Avatar
One of my mentors suggested using Nova carby with Hyper 12. Has anyone else tried as supposed to fit straight in. Sounds like would work well as adjustment low speed needle unlike stock Hyper carby? I will try it as have spare Novarossi motor in shed when get the chance. John Tan where did you get the Orion CRF manifold and pipe? Good price?
Old 02-26-2007, 06:13 AM   #506
I switch to GPX4 because of my sponsor.
Here's a link I've already gave.
A presentation of my car.
My GPX4 Pro
bye
Old 02-26-2007, 06:37 AM   #507
dr_catman's Avatar
another one with my fav tyres ...
hi john, sure is a good looking car. Btw, did you mount your radio equipment in firmly. did they tell you to use tape or any other thing to prevent the same problem?
BTw, just got a hyper 7 buggy. Are you getting any off-road?
dr_catman is offline   Reply With Quote
Old 02-26-2007, 06:56 AM   #508
vc05hdt's Avatar
Originally Posted by Bundy_Bear
Hi
BB
Bonjour Romuald, I see in your set up sheet that you use gear diff in Pro car with 100k oil and not one way diff in front. What are your tracks like to run that combination?
Old 02-26-2007, 08:23 AM   #509
JOHN TAN's Avatar
ok I see... btw where do u get it?
Old 02-26-2007, 08:26 AM   #510
JOHN TAN's Avatar
wah...why don't just use the original Nova engine?
I got the manifold and pipe at [email protected] around US$100...
Hobao GPX4 Pro grassrootsracer Australia Wanted to Buy 4 06-15-2008 10:49 PM
HoBao GPX4 Pro hooked_on Australia For Sale/Trade 2 12-08-2007 12:54 AM
HoBao GPX4 Pro w/ STS 12 D3R hooked_on Australia For Sale/Trade 0 12-01-2007 01:22 AM
HPI R40 vs Hobao GPX4-PRO ernstb Nitro On-Road 3 02-27-2007 12:16 PM
HOBAO GPX4 hobby racr Singapore R/C Racers 0 12-12-2005 03:58 AM
