Old 11-10-2006, 05:10 AM   #376
OleC's Avatar
Good tips
Thanks guys!
So most of you use a front diff? Have anyone seen or used a solid axle (spool) on this car?
OleC is offline   Reply With Quote
Old 11-10-2006, 08:11 AM   #377
three50zx's Avatar
I tried to run a front diff but decided to go back to the one-way because of better lap times. I haven't seen a solid in particular but there are many ways to turn a diff into a solid.
three50zx is offline   Reply With Quote
Old 11-11-2006, 05:17 PM   #378
SnakeEyz's Avatar
Default CRF on GPX4
Ole C my friend runs a CRF on his GPX4 and I also run one on my RRR. I do his clutch and motor tunning for him and have gotten this motor to perform extremely well on both cars. For the track you are talking about running on the gearing you want to use is 20/26, 60/54. And for your clutch you want to run 1.1 spring tension and .5 clutch gap depending on the traction of the surface you run on, if high traction you can go 1.2 on the spring and .6 on the clutch. motor will have more than enough bottom and insane top hope this helps.
Shepherd Velox V10/ KO Propo/ Novarossi Engines/ Team NLR/ V.O.R.R.A./ 301(Forever)/ AKA. Darryl Hurling
SnakeEyz is offline   Reply With Quote
Old 11-12-2006, 10:06 AM   #379
OleC's Avatar
Thank you SnakEyz!
Just the kind of info I was looking for!
Much appreciated!
Cheers.
Ole C
Old 11-12-2006, 05:25 PM   #380
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
Guys,
Had a win on the weekend with my RTR car with the TZ3 engine in it. The car seems to handle much better than my Pro GPX-4 and I find this strange as all the settings are the same all I can think is maybe the extra chassis flex makes the car grip up better than the stiffer Pro chassis still having a few clutch problems with the car freereving between gear changes.
Taffyjnr5
Taffyjnr5 is offline   Reply With Quote
Old 11-13-2006, 10:39 AM   #381
Default internal ratio
Originally Posted by Taffyjnr5
Hi,
Does anyone know the internal ratio of the GPX-4 Pro. Thanks
Taffyjnr5
Hey Taffyjnr5 the internal ratio of the GPX-4 pro is 2.4238 so for the 1st is 47/16*2.4238=7.12 and for 2nd is 43/20*2.4238=5.21
alexrgz is offline   Reply With Quote
Old 11-14-2006, 05:36 AM   #382
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Hey Guys, been reading alot on the Hobao,as i got one for my 30th birthday from a bunch of mates, pretty cool little toy thats for sure and addictive TOO!!!
The make i have is Hyper 10 with a H12 Nitro Motor in it....!
Question how differant are these from the GPX4-PRO
I have only had the car for a week, done a rear drive gear & rear drive belt due to rocks getting inside and splitting the belt....! OUCHIE
The plastick gear was melted on half side, as i think the rock got the better end of the day LOL, but spen AUS$40 and she no worries again!!!!
What tips can i get for a Fast Circuit CAR - setup wise any links etc for my Hobao Hyper 10 & What setup is good for a Drift Style set up?
Some good links to help a ROOKIE like myself understand this new crazy Hobby my mates got me, now i need to learn a whole new world!!!
Regards
Frankie
Hobao GPX4 Pro-img_0137.jpg   Hobao GPX4 Pro-img_0147.jpg   Hobao GPX4 Pro-img_0148.jpg
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 11-22-2006, 05:34 PM   #383
mac75's Avatar
Trader Rating: 3 (80%+)
Default GPX4Pro
This is my car
[IMG]Hobao[/IMG]
mac75 is offline   Reply With Quote
Old 11-22-2006, 06:27 PM   #384
what weight diff oil do you guys recommend for the rear diff ? i am building a pro version with the front one-way.
thanks
baih is offline   Reply With Quote
Old 11-22-2006, 09:38 PM   #385
Taffyjnr5's Avatar
Hi,
I am currently using Mugen diff oils with 30k oil in the rear of my Pro car and using 50kr ear and 100k front in my RTR Sport class car and I have found these to be the best for most tracks so far. Hope this helps you out.
Taffyjnr5
GPX-4 Pro
OS TZ(3)
Spekrum
Old 11-27-2006, 10:00 AM   #386
three50zx's Avatar
I have actually started to run 100k diff oil in the rear of my car with a front one way and I've become a better driver. Putting 100k in the rear has taught me throttle control like never before. Definitely try 10k, 30k, and 100k to see what works best for you at your local track. Experimenting will only make you a better driver. Good luck.
Old 11-30-2006, 05:07 AM   #387
MAJOR's Avatar
Send a message via Yahoo to MAJOR
Hi everyone! Just asking,do many of u people stil run a hobao gpx4 pro or rtr?
Ahhooo!!! Ahhooo!!! Ahhooo!!!
MAJOR is offline   Reply With Quote
Old 12-02-2006, 01:53 AM   #388
Taffyjnr5's Avatar
Hi,
I run both a Pro with a OS TZ3 and a RTR in sport class with a OS TGP and have a lot of success with both cars at club level.
Taffyjnr5
Old 12-02-2006, 01:56 AM   #389
Taffyjnr5's Avatar
Funny you should say that i have started experimenting with the oneway and rear diff oils currently using 50k rear and it has made me a better driver.
Taffyjnr5
Old 12-02-2006, 07:06 PM   #390
MAJOR's Avatar
Hi,
Taffyjnr5
Ah okay thanks... Do many still run these kits in your place?
Hobao GPX4 Pro grassrootsracer Australia Wanted to Buy 4 06-15-2008 10:49 PM
HoBao GPX4 Pro hooked_on Australia For Sale/Trade 2 12-08-2007 12:54 AM
HoBao GPX4 Pro w/ STS 12 D3R hooked_on Australia For Sale/Trade 0 12-01-2007 01:22 AM
HPI R40 vs Hobao GPX4-PRO ernstb Nitro On-Road 3 02-27-2007 12:16 PM
HOBAO GPX4 hobby racr Singapore R/C Racers 0 12-12-2005 03:58 AM
