Old 10-07-2006, 01:58 AM   #361
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
Guy's
What clutch shoes are you guys using the standard GPX-4 ones or is there some aftermarket ones like Mugen,Kyosho.
Taffyjnr5
Taffyjnr5 is offline   Reply With Quote
Old 10-08-2006, 02:28 AM   #362
GoFast's Avatar
Send a message via MSN to GoFast
I am using the standard black shoes. They seem to be good for me. I have a Sirio engine and they hold up well. The other kind I have seen used in a GPX4 are blue and are softer for more bite.
GoFast is offline   Reply With Quote
Old 10-08-2006, 08:47 AM   #363
Taffyjnr5's Avatar
Hi,
What brand are the blue ones that you use and does anyone use Teflon or Rulon or even a CRF clutch as I noticed the Serpent 710 CRF conversion looks the same.
Taffyjnr5
Old 10-09-2006, 08:43 AM   #364
three50zx's Avatar
Part #22159 - Blue SP centrifugal shoe
They are a bit on the soft side but work very well.
three50zx is offline   Reply With Quote
Old 10-10-2006, 05:00 AM   #365
Hi
My GPX4 Waiting for Rebuild
i get the parts form here:
http://www.rc-union.com
initialrays is offline   Reply With Quote
Old 10-14-2006, 03:51 AM   #366
Taffyjnr5's Avatar
Guys,
Still having uber problems with my clutch setup does not matter what i do it still seems to slip even with new shoes and shimming to spec i have heard that the standard Hobao centre spring is too stiff is this the case or not.
Taffyjnr5
Old 10-19-2006, 08:04 AM   #367
three50zx's Avatar
Hi Taffyjnr5, I am using the Hobao spring with not problem. If you think that's the problem squeeze the spring with pliers a few times and then try it. Check to make sure your brake is not applied when everything is installed. Maybe you have too many shims take a few out and try it.
Old 10-19-2006, 08:20 AM   #368
three50zx's Avatar
Originally Posted by initialrays
Hi
Looking at your car it looks like you are using a different rear hub. Which one are you using?
Old 10-20-2006, 12:55 PM   #369
I useing Vone RRR rear hub.Mugen Damper.
Old 10-24-2006, 06:13 PM   #370
three50zx's Avatar
Any modifications needed to get this to work, it's always good to know considering I have a friend that runs the RRR. It's always easier to bum parts from someone you know. LOL
Old 11-03-2006, 10:15 AM   #371
Turbine_au's Avatar
Originally Posted by Taffyjnr5
Guys,
Taffyjnr5
Try making the clutch adjustment nut a little bit looser. Mine came from the factory WAY too tight. Car would just sit there and rev and go nowhere. Screwed it out a bit and off it went. Which reminds me, I need to readjust that, my starts are shocking.
For the people using the Hyper 12, are they getting many issues. Mine is the RTR so im sticking with the engine for a while. Mine is a pain to tune. The biggest problem is flameouts mid tank as the fuel level drops. So of course, when the tank is full, it's a rich running slug but slowly gets quicker as the fuel level burns off. Basically, I just tune it to last a full tank.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 11-05-2006, 08:34 AM   #372
OleC's Avatar
Has anyone here tried the Orion REV .12 engine in the GPX4 PRO?
Just wondering if theres any mods that need to be done, or special conciderations to take.
I know i probably must find some other gears to make it work on my local track which is fairly tight and technical. According to Orion this engine needs a lot higher gear ratio than other engines to work properly...
Cheers
Ole C
OleC is offline   Reply With Quote
Old 11-05-2006, 09:42 PM   #373
Taffyjnr5's Avatar
Hi,
Does anyone know the internal ratio of the GPX-4 Pro. Thanks
Taffyjnr5
Old 11-06-2006, 09:27 AM   #374
Hello from Fra,
here's a little presentation I made for a french Website.
Sorry , it's in french...
http://www.automodelisme.com/modules...wtopic&t=21124
romuald31 is offline   Reply With Quote
Old 11-09-2006, 09:57 AM   #375
Here's a picture of the main modification that improve a lot my car.
Put the mounting of the rear anti-roll bar inside the arm.
The anti-roll is harder and the car is better.
Hobao GPX4 Pro grassrootsracer Australia Wanted to Buy 4 06-15-2008 10:49 PM
HoBao GPX4 Pro hooked_on Australia For Sale/Trade 2 12-08-2007 12:54 AM
HoBao GPX4 Pro w/ STS 12 D3R hooked_on Australia For Sale/Trade 0 12-01-2007 01:22 AM
HPI R40 vs Hobao GPX4-PRO ernstb Nitro On-Road 3 02-27-2007 12:16 PM
HOBAO GPX4 hobby racr Singapore R/C Racers 0 12-12-2005 03:58 AM
