Old 07-17-2006, 02:37 PM   #316
i called ofna today. the plastic mount for the side tensioner and the alumimun require different hardware not included in the kit. they are sending the parts neccesary to mount the bearings for the side tensioner.
baih is offline   Reply With Quote
Old 07-23-2006, 09:26 AM   #317
Turbine_au's Avatar
I just picked up a GPX4 RTR. I'm having trouble getting the 4 AA's to fit in the battery box. The batteries themselves, fit fine, but the connecter between the pack and the switch stops everything from sitting in there right without bulging in one direction or the other. Someone got any ideas on how to make it fit right?
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 07-23-2006, 01:46 PM   #318
nitrodude's Avatar
Does the PRO come with the 0.8 gears?
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 07-23-2006, 05:56 PM   #319
Trader Rating: 22 (100%+)
Send a message via ICQ to cmain
yes the radio and battery box design on the RTR is awfull. I had to do some major dremel work to make everything fit. a five cell hump pack fits better and lasts longer so I suggest you pick one up.
cmain is offline   Reply With Quote
Old 07-23-2006, 07:33 PM   #320
Turbine_au's Avatar
That's next on the list, plus I need to get one for my hyper 7 as well.
Also, can someone run me through how to adjust the clutch, I couldn't find anything in the manual about it.
Old 07-24-2006, 08:42 AM   #321
Turbine_au's Avatar
Anyone know how to adjust the centax clutch?
Old 07-24-2006, 05:26 PM   #322
there is a little hole on the clutch bell that allows you to stick a allen wrench in to tighten or loosen the clutch spring. I have mine set about flush on a mt-12
Old 07-25-2006, 09:55 PM   #323
Turbine_au's Avatar
I found the hole in the clutch bell but there wasn't a screw or similar in there.
Old 07-25-2006, 10:29 PM   #324
here is a picture of the inside part you adjust.
Old 07-25-2006, 11:55 PM   #325
Turbine_au's Avatar
Oh ok, I think I know what's going on now. Thanks for your help.
Old 08-03-2006, 06:40 AM   #326
stefke's Avatar
After years of loyal service (and good performance ), i laid my NTC3 FT to rest and ordered a GPX4 Pro.
One of the fine things about the NTC3 was that Team Associated's Set-ups were available online and they always proved to be a good starting point to find the perfect setup.
My question : are (Team) setups for the GPX4 available online somewhere and where can I find a blanc setup sheet ?
stefke is offline   Reply With Quote
Old 08-06-2006, 09:00 PM   #327
here is a setup that a pro driver sent me it is for a large track.
Front -
45 wt
top of shock all the way in
HPI Blue spring (HPIC
swaybar flat
1 small caster clip in front
1 deg. toe out
one way
2 deg camber
198 mm width
droop 1mm over ride height
Rear -
40 wt
top of shock all the way out
HPI orange spring (HPIC
camber link in top hole on hub carrier
outer hole on bulkhead
stock swaybar
2 deg toe in
100K diff oil
3 deg camber
droop 3-4mm over ride height (adjust for off power turn in)
OFNA CD3 power clutch
O.S. Speed 12 TZ
O.S. T1040 pipe and header
Tires -
GRP 40 front 42 rear
Body
Parma M type (Protoform Stratus 3.1 works well also)
Old 08-19-2006, 10:22 AM   #328
three50zx's Avatar
thanks for the setup. I plan on trying parts of this setup later today at our local track. I will let you know how it goes.
three50zx is offline   Reply With Quote
Old 08-19-2006, 10:29 AM   #329
royfan33's Avatar
Default Hobao or Ofna
Hi to all. New guy to the forum and 1/10 onroad. My buddy and I are looking to try some 1/10th onroad after having 1/8th buggies, boats, planes, ect since '93. We are fans of Ofna/Hobao after having some of their buggies.
My question is...is the Gpx4 Pro from OFNA substantially different from the one we can get from Hong kong? The only diff I can see is the lack of a pipe from Hong Kong. Though it seems for the price diff there may be more...
Please advise....We are anxiously waiting to order.
thanks
royfan33 is offline   Reply With Quote
Old 08-19-2006, 10:43 AM   #330
three50zx's Avatar
The GPX4 from Ofna came with all the aluminum parts and a pipe. I posted some pics of my car earlier in this thread. I think the one in Hong Kong comes with plastic supports and limited graphite, not sure though. This car is great you will love it. Very easy to setup and the drivability is exceptional. Good luck.
Hobao GPX4 Pro grassrootsracer Australia Wanted to Buy 4 06-15-2008 10:49 PM
HoBao GPX4 Pro hooked_on Australia For Sale/Trade 2 12-08-2007 12:54 AM
HoBao GPX4 Pro w/ STS 12 D3R hooked_on Australia For Sale/Trade 0 12-01-2007 01:22 AM
HPI R40 vs Hobao GPX4-PRO ernstb Nitro On-Road 3 02-27-2007 12:16 PM
HOBAO GPX4 hobby racr Singapore R/C Racers 0 12-12-2005 03:58 AM
