Old 02-28-2006, 03:37 AM   #226
NARNYRX3's Avatar
i've found the h.12 doesn't have the torque of the o.s.in std form. i had one of these engines in an fw05rr and found they are a little lacking down low. i have just got into it with the dremel so i will let you know how it goes when i give it a run
NARNYRX3 is offline   Reply With Quote
Old 02-28-2006, 05:57 AM   #227
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
Got my car today checked it over and took it down the track for a run and half a lap later the reciever pack went flat (BUGGER!!) engine sounds good though. What is a good rear diff oil to run first off as I am new to Nitro I think the kit is 30000 should I start there and it has a front oneway.
Taffyjnr5
Taffyjnr5 is offline   Reply With Quote
Old 02-28-2006, 10:46 AM   #228
Francis M.'s Avatar
Taffyjnr5
I used ofna 30,000 diff oil and it seems to be a good starting point for my local track.
Francis M. is offline   Reply With Quote
Old 03-08-2006, 06:29 AM   #229
Send a message via Yahoo to mykel chua
simonr23, Heres the thread for HObao GPX4. browse through from the beginning of the thread and youll get your reviews
mykel chua is offline   Reply With Quote
Old 03-08-2006, 06:36 AM   #230
Taffyjnr5's Avatar
Had another run with my car yesterday (with a full receiver pack this time) and it is a nice car to drive was a bit taily at first but i increased the toe in at the rear and changed shock oil to 35wt and that seemed to help.Still running motor in so I cant wait to race this weekend.
Taffyjnr5
Old 03-09-2006, 04:45 AM   #231
Taffyjnr5's Avatar
I ran my GPX-4 again today and am having motor issues I run a Nosram Vtec .12 I set the main and mid to their factory settings and to start with the car runs like a rocket for about three to four laps and then it seems to off tune itself sounding horrid and sometimes it stalls engine temp gets up to about 90-100C and it practically new.
Taffyjnr5
Hyper GPX-4
Nosram Vtec .12
Spektrum DSM
Old 03-11-2006, 12:55 AM   #232
Taffyjnr5
Hyper GPX-4
Nosram Vtec .12
Spektrum DSM
Hi! did you follow the break in procedures properly?
Old 03-11-2006, 07:23 AM   #233
Taffyjnr5's Avatar
Yes I did I ran 4 to 5 tanks I ran the main at 5 turn and the mid at 6 turns and putted around my home track not going over half throttle and not going over 90C in temp I am racing tomorrow so I have changed the fuel line and cleaned the carb and changed the exhaust gasket and see if that helps!
Taffyjnr5
Old 03-12-2006, 04:15 AM   #234
Alfa Sprout's Avatar
for a start buy a O.S or try changing the high speed mixture screw o-ring that may cause it to come off tune dude to vibrations it will of tune if the o-ring is shaged if not buy a O.S
Alfa Sprout is offline   Reply With Quote
Old 03-12-2006, 07:41 AM   #235
i second this. OS works even if your setting is bad. Anyway, heres my break in process maybe this could help you...
run 3 tanks on engine hanged no throttle (must be on the neutral setting)
rest
set the full throttle opening to only 25% and run 5 tanks around the track
rest
set the full throttle opening to only 50% and run another 5 tanks around the track
rest
set the full throttle opening to 100% and run 3-5 tanks
after this you can start adjusting the high speed needle to lean. Be careful in setting too.
Old 03-13-2006, 01:50 AM   #236
Taffyjnr5's Avatar
Thanks for that,How much are the O.S. engines in AU$ and what is the model number. I raced it on the weekend and won my first Qual and finished third overall in the final.
Taffyjnr5
Old 03-15-2006, 07:09 AM   #237
Taffyjnr5
Congratulations on your 3rd place finish! Better get and OS .12TZ
Old 03-16-2006, 02:11 PM   #238
Swamp Rat's Avatar
Default GPX4 PARTS
Hey Guys Where can i get PARTS for the GPX4 in Brisbane QLD
Also is a Pro upgrade kit available in Aus
LCRCCC. inc. The Greatest Club in QLD.
Come see our great new layout.
Schumacher Mi6 x 2,Yokomo BD7, Roche F1, SP F1 x2,Serpent SF2 F1, MO5 mini, M03 Mini, Corally F1 on Rubber, Futaba 4PX,
Ax10, SCX10, Joker Visit : www.lcrccc.org.au
Swamp Rat is offline   Reply With Quote
Old 03-21-2006, 11:00 PM   #239
Taffyjnr5's Avatar
I bought mine off Ebay but it came with receipts form either Hobby Haven or Hobby Habit from South Australia Iwill have to check when I get home but hope this helps anyway.
Taffyjnr5
Old 03-27-2006, 02:28 PM   #240
Francis M.'s Avatar
congratulations to Jeffrey lin for putting the gpx4 in the winners
circle at the airtronics championship held in revelations raceway.
Hobao GPX4 Pro grassrootsracer Australia Wanted to Buy 4 06-15-2008 10:49 PM
HoBao GPX4 Pro hooked_on Australia For Sale/Trade 2 12-08-2007 12:54 AM
HoBao GPX4 Pro w/ STS 12 D3R hooked_on Australia For Sale/Trade 0 12-01-2007 01:22 AM
HPI R40 vs Hobao GPX4-PRO ernstb Nitro On-Road 3 02-27-2007 12:16 PM
HOBAO GPX4 hobby racr Singapore R/C Racers 0 12-12-2005 03:58 AM
