Old 04-12-2014, 09:04 AM   #1
racerx1920's Avatar
Trader Rating: 210 (100%+)
Default Ofna gtp setup sheet
I have been looking for a setup sheet for this car and I cant find one anywhere. I'm looking for a setup for a high bite asphalt track that would be a good starting point.
Desoto Racing / Serpent America / ProOne RC
Serpent 748WC / Serpent s120LTR / Serpent Project 4x
Dunn Graphics
1/8th Scale Racers of Toledo
https://www.facebook.com/DunnGraphics1
racerx1920 is offline   Reply With Quote
Old 04-12-2014, 09:53 PM   #2
azeroth's Avatar
Trader Rating: 20 (100%+)
which version of the chassis do you have? blue chassis with or is it the gtp2 which is a gun-metal color 500k front diff 50k rear 1 degree toe out front 2 degrees toe in rear 1.5 chamber front 2 degrees chamber rear front upper arms upper position centered in clips short link rear in top position inside and lowest on the rear knuckle white springs on the front 3000 weight yellow springs rear 2000 8-10mm ride height if the chassis hits under braking you to yellow front spring
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake,VP,Radiopost,Protek,EDS,Matrix
Team Nitro RC Club
azeroth is offline   Reply With Quote
Old 04-13-2014, 07:11 AM   #3
racerx1920's Avatar
its a GTP2 with the gun metal chassis. thanks for the help.
you said 3000/ 2000 for the shocks that is CTS?
Dunn Graphics
