Old 04-09-2014, 12:35 PM   #1
Evo 13's Avatar
Default I need a cure for tire ballooning?
Hey all,
I'm working a fun project where I'm converting my 747 racer into a replica looking street car—BMW M3 hpi body. Problem is, in order to fit the look I'm going after I need 3mm and 6mm offset wheels and low pro rubber tires. (foams won't cut it). But I know the rubber will balloon at high speeds, ruining my shell and adversely affecting the handling. So for all you creative minds out there, is there anyway I could prevent the tires from ballooning at high speeds?
Thanks in advance.
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Mugen MBX7T ECO (Truggy)
SMC, Max Amps, LRP, Poseidon Motors, Cordova Research Motors, Xceed.
Evo 13 is offline   Reply With Quote
Old 04-09-2014, 03:07 PM   #2
Pit-racer's Avatar
Ol' skool Duct Tape.
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 04-09-2014, 03:16 PM   #3
azeroth's Avatar
Trader Rating: 20 (100%+)
sweep makes a belted tire for the application
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 04-09-2014, 03:21 PM   #4
RazzBarlow7's Avatar
Fiberglass stranded packing tape on the inside of the tire.
My wallet sponsors the following companies: Tekno, X-Factory, Schuur Speed, Tekin, SDRC
B4.1 (retired)
Tekno SCT410, Schuur Speed 4300KV, Tekin RX8, Reedy 7000mah
X-Factory Cubed #163, Schuur Speed 17.5, Tekin RS Gen 2, XP1015, Reedy 4100 Shorty
UNDER CONSTRUCTION: X-Factory SCX60-CF #132
RazzBarlow7 is offline   Reply With Quote
Old 04-09-2014, 04:53 PM   #5
Evo 13's Avatar
Thanks for the tips, I found a wealth of youtube videos supporting the duck tape idea, but not the fiberglass tape—I'll explore that option further.
Sweep was my initial choice and so I called earlier today, but they told me their tires are 24mm not 26mm. From there I came here.
Kinda excited to replicate this look again:
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 04-09-2014, 05:08 PM   #6
Trader Rating: 15 (100%+)
i got this tip from a friend of mine…
he used braided fishing line…tied and glued the string and voila…no more ballooning…
i thought it was pure genius…too bad i can't take credit for it.
IvVaum is offline   Reply With Quote
Old 04-09-2014, 05:21 PM   #7
howardcano's Avatar
Trader Rating: 35 (100%+)
How about belted HPI X-Patterns? They're not super-low profile, but they might do the trick:
http://www3.towerhobbies.com/cgi-bin...?&I=LXM980&P=0
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 04-09-2014, 05:25 PM   #8
Geezatec's Avatar
Find tire insert that fits the tire, HPI used to have tire inserts in different colors, soft, medium & hard. Use rubber cement that does not dry quickly. Glue insert to the tire. Mount it on rim then cement or Elmer's glue. last CA to bead to the rim. Let dry at least 12 hours. Just Brainstorming it, but it makes sense to me. Ballooning happens when there is nothing but air in it. stuffing anything may become imbalanced. Find a insert that fits the tire.
Geezatec is offline   Reply With Quote
Old 04-09-2014, 05:25 PM   #9
Jspeed's Avatar
Thumbs up
Thanks in advance.
You might want to try a set of tires that look like this on the inside.....
Vulcanized belts inside of the actual rubber are best for high speeds.
Good luck & have fun!
Jspeed is offline   Reply With Quote
Old 04-09-2014, 05:39 PM   #10
Evo 13's Avatar
I think I had those tires before, they come with the rs4. If they are the same, they ballon a bit.
Would vulcanized belts effect the weight much?
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 04-09-2014, 05:42 PM   #11
Evo 13's Avatar
Any balancing problems?
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 04-09-2014, 06:09 PM   #12
not enough for you to notice…gotta get those expensive braided fishing lines though…they don't stretch and once glued with the CA tire glue…they hold up real well…
can't do it to the slicks…but the treaded designs…works like a charm…and u don't even need to tie it…just wrap around twice…and glue…
i tie it cos i don't really care too much about balancing.
