Old 08-10-2005, 08:48 PM   #1
Unhappy HPI RS4 3 EVO - Tuning
i purchased the rs4 3 evo about a week ago. i have passed the break in period, currently anywhere between 10 and 12 tanks. so i am starting to open it up and go full throttle, and i'm having problems there....
the manual says to start with a baseline tuning, so i did; HSN 3 turns out from closed, and the LSN just about flush (more lean). with that, if i squeeze the trigger, it moves, but does not shift, and really starts to stutter. so, i found that leaning it more did the trick. BUT, by the time it was running well, i'm probably anywhere between 1.5 and 2 turns out. that sounds like a lot to me! is that normal? i can see a little smoke coming out, but not like my other cars/trucks when tuned right; they have a lot more...
i brought it to my local hobby store to have them look at it for a few mins. they were saying its too lean at the top end, so they tried to richen the HSN. that didn't work. they recommended a different type of fuel, because the 20% traxxas fuel i was using, they said, has A LOT of oil. i have some white lightning at home too... think that will help?
ocgstyles is offline   Reply With Quote
Old 08-11-2005, 02:16 AM   #2
nsxshogun's Avatar
Send a message via AIM to nsxshogun
White lightning......
A+++++++
Yea thats for sure the problem. I had my buds at 312 with some old blue thunder, I think? , with his hpi motor that came with his rs4 ss. It ran perfectly. Then I riched it a little. Those HPI motors like to run hot.
nsxshogun is offline   Reply With Quote
Old 08-11-2005, 09:21 AM   #3
Jye
if they have some blue thunder, use that.
Jye is offline   Reply With Quote
Old 08-12-2005, 02:14 PM   #4
Ceratog's Avatar
Send a message via AIM to Ceratog Send a message via Yahoo to Ceratog
I'm running blue thunder in my RS4 3 EVO. I live in a high temp, high humidity area and I've noticed it doesn't like to crank up unless the high end needle is a little lean (about 2 and a half turns out). Once she warms up I have to richen her up a bit. For some reason, she won't start when the needle is at the optimum running setting... go figure.
Ceratog is offline   Reply With Quote
Old 08-12-2005, 05:43 PM   #5
nsxshogun's Avatar
Exact problem I had when I was helping my bud out with his SS
Old 08-14-2005, 08:10 AM   #6
i was just using it last night for about an hour and a half. it was turned between at about 2 turns out, using white lightning. i guess it does like to run like that... it doesn't stutter at full throttle when its leaned that much, so its getting fuel... i guess i'll find out depending on how long the motor lasts. the only thing that broke last night was the wing on the bmw body...
Old 06-21-2009, 03:37 AM   #7
calrosse's Avatar
Talking
Does anybody know how to adjust the tranny on these i want it to shift at a higher speed. Any info would be helpful thanks
calrosse is offline   Reply With Quote
Tuning Class..any SIFU (klang valley) offer engine tuning class??.. azmin Malaysian R/C Racers 17 06-20-2008 10:42 PM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 07:04 PM
beginner questions re: car tuning and motor tuning! Captjono Rookie Zone 5 02-19-2005 12:01 PM
beginners question re: car tuning and motor tuning! Captjono Electric On-Road 5 02-19-2005 03:01 AM
tuning sloedown Nitro On-Road 5 08-19-2003 06:33 AM
