Old 07-16-2014, 10:09 AM   #61
Trader Rating: 24 (100%+)
some things i would try....
first...
add some weight to the rear of the car
decrease ackerman (increase the angle of the steering rods)
if that doesnt help, try these in this order:
soften front springs or lean in front shocks
soften front sway bar
more front camber or less rear camber...
more rear droop
lower front roll center or raise rear roll center
Start with these... ONE CHANGE AT A TIME!
Justin Cornett
RC America / XRAY / HUDY / KoPropo / Team EA Motorsports / AVID RC / RSD / ReflexRacing.net
gocoogs is offline   Reply With Quote
Old 07-16-2014, 09:39 PM   #62
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
Originally Posted by Giant655 View Post
Okay, let me know if I missed anything, still have a lot of things set to manual/stock specs.
Shocks; 600 wt f/r
Springs 7.5/5.0 f/r
Shock holes 4 (1.1mm) f/r
Ride height 8/8.5mm f/r
Toe -1.5/-2 f/r
Camber -3/-2 f/r
Short wheelbase
Stock width
Caster; stock
Roll center; stock setting/high eccentric bushings f/r
Eccentric bushings; stock (forward and up) f/r
Shock hole mounting; stock. Is hard to get an accurate measurement on the bumper length because of an indent on the body there, but from the center of the bumper (where it has the molded indent) I got about 28 mm, and like I said im running the p909
So a couple things I would change up front and think you would notice a major improvement.
1) P909 - ok at best even when mounted all teh way to the front. Change over to the Matrix cause you have one on the way and you will see an instant increase in steering with the car.
2) run 252 mm of front track width and 263 mm of rear track width. Track width is one of the biggest things that can affect the way the car handles
3) change the front springs from 7.5 to 7.0 springs.
4) are you running a blade sway bar or the wire roll bar? If you are running a wire roll bar run a blade bar and lay it flat.
That is where I would start.
To answer your questions about hard version of the bulkheads and arms. Xray makes an alternative plastic compound that is harder. I personally really like the hard bulkheads and hard rear arms.
Jay Williams
Xray RX8 2014
RC America - Protoform Racing - KO Propo USA - Kevco Racing / Picco EDO Modified - Byrons Fuels
OnRDPassion is offline   Reply With Quote
Old 07-24-2014, 03:59 PM   #63
GMartinez's Avatar
Trader Rating: 85 (100%+)
just noticed they had 1 instock www.superiorhobbies.com
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 07-24-2014, 03:59 PM   #64
GMartinez's Avatar
Old 08-28-2014, 12:18 PM   #65
Evo 13's Avatar
Got a bulk sale of some new 1/8 foams, check For Sale thread if interested.
http://www.rctech.net/forum/r-c-item...l#post13498111
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Mugen MBX7T ECO (Truggy)
SMC, Max Amps, LRP, Poseidon Motors, Cordova Research Motors, Xceed.
Evo 13 is offline   Reply With Quote
Old 09-17-2014, 01:35 PM   #66
nitrobeast's Avatar
Trader Rating: 41 (100%+)
New to 1/8th on-road and need some advice on torque needed for steering and throttle/brake servo. Leaning towards using savox servo. Been using them on all my TC for the last 3 years without any issues.
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 09-17-2014, 04:55 PM   #67
azeroth's Avatar
Trader Rating: 20 (100%+)
in my second car i run a sc1251mg on the throttle and a sc1258tg on the steering on 6.6
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 09-24-2014, 02:54 PM   #68
JamesHealey's Avatar
Savox SC1258TG on steering & throttle, awesome servo!
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
Old 10-05-2014, 08:35 AM   #69
nitrobeast's Avatar
So is it safe to say 150 to 200 of torque is what we need?
Rui Goncalves
Old 02-22-2015, 03:29 AM   #70
peter.'s Avatar
the xray rx8 is just as good as the other cars like the serpent shepherd mugen
peter. is offline   Reply With Quote
Old 02-24-2015, 04:07 AM   #71
Im running 13' spec and have been having the same handling issues, that off power push that kills corner speed
More rear droop?
Serpent 977
jtrmx250 is offline   Reply With Quote
Old 05-11-2015, 11:05 AM   #72
brothainchrist0's Avatar
Trader Rating: 145 (100%+)
Hey guys, I am picking up a very lightly used RX8 2012 that is highly upgraded from what I'm being told. Am I screwing up buying this car? Is there a big difference between the 2012 and the 2013?
2017 Xray RX8 - Ielasi Modified Engines/Matrix Tires/Savox Servos/Airtronics Radio
IGT Hobbies - The one stop shop for anything on-road and incredible customer service.
brothainchrist0 is offline   Reply With Quote
Old 09-22-2015, 09:06 AM   #73
Trader Rating: 2 (75%+)
Anyone have a good starting point setup for the Greater LA race track? I'm racing in the Ko Propo this coming weekend and this will be the 1st time running my RX8 in LA.
kingtito is offline   Reply With Quote
Old 09-22-2015, 11:18 PM   #74
iwk2much's Avatar
Here you go.
http://forum.teamxray.com/xform/inde...D=80&setup=rx8
The only change is the front shock oil at 1200, rear at 1000 weight oil
Come and stop by the Xray pits. There will be alot of help available.
Mike Strack
iwk2much is offline   Reply With Quote
Old 09-23-2015, 09:41 AM   #75
Thank you
