Old 08-09-2005, 02:46 PM   #1
Default Best surface for onroad
Ok so here is my question, most outdoor tracks that i have seen have been made of asphalt. However i have never seen one that is made of concrete. It seems to me that some textures of concrete have much better traction than asphalt and when done properly are much smoother than asphalt. Any other ideas on this would be helpfull.
Lee
ATXPro4 is offline   Reply With Quote
Old 08-09-2005, 04:03 PM   #2
ziggy12345's Avatar
Lee
No traction on concrete. There is a non slip coverage for concrete but its so abrasive you need 2 sets of tyres for a 5 min heat.
The best surface for Asphalt is 6mm SMA with a high rubber content. This gives massive grip and a low wear rate
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 08-09-2005, 06:50 PM   #3
mistercrash's Avatar
R/C Tech Charter Subscriber
Cheers
Forgive my ignorance but what is SMA? Can you elaborate? Is it a coating that is applied over existing asphalt? If so, do you know of any companies that do it?
No brain, no headaches.
mistercrash is offline   Reply With Quote
Old 08-10-2005, 02:09 AM   #4
SMA=Stone Mastic Asphalt. It's a type of asphalt, not coating. Sure, you could probably use it as a top layer over existing asphalt, but you might have to plane some material off the existing surface.
Any road construction company should be able to help, I suppose.
olev is offline   Reply With Quote
Old 08-10-2005, 04:02 AM   #5
nsxshogun's Avatar
Send a message via AIM to nsxshogun
Don't really know what the hell you guy's are talking about but .......
I am in hawaii and outside of the house I'm staying is some very smooth asphalt. Which of course gives sorry traction. But I have something in front of my house in maryland which gives vey good traction but its got alot of pebbles and rock every where. Makes ya wonder......
nsxshogun is offline   Reply With Quote
Old 08-10-2005, 05:33 PM   #6
Thanks olev
Can a surface be too smooth? Baedarlboo Georgia Racing 8 04-25-2008 07:44 AM
WTB: Looking for a Hi Tech FM surface transmitter NTC3Crazy R/C Items: Wanted to Buy 0 03-31-2008 06:57 PM
knox's surface ????? simba Australian Racing 8 08-28-2007 04:56 AM
set up tips for wet surface pearl Electric On-Road 10 06-28-2007 10:29 AM
ruberized surface tallyrc Electric On-Road 9 11-03-2006 08:48 PM
