Old 08-08-2005, 02:56 PM   #1
dct147's Avatar
Default bent chassis plate
Hi all,
due to the irresponsible fellow at my track who turned on his transmitter after informing him , this has happened.
I`ve tried knocking it, heating it then hammering it, but it still won`t budge.
does anyone know of a better way?
thanks in advance.
bent chassis plate-bad-bang-1.jpg   bent chassis plate-bad-bang-2.jpg   bent chassis plate-bad-bang-3.jpg
dct147 is offline   Reply With Quote
Old 08-08-2005, 03:19 PM   #2
j03s4y's Avatar
Send a message via AIM to j03s4y
Solution: Make the guy pay for a new chasis. Or if it's alluminum..........try heating it with a torch and banging it just a little......
j03s4y is offline   Reply With Quote
Old 08-08-2005, 04:01 PM   #3
dct147's Avatar
he`ll probably deny just as i asked him y did he turn on his transmitter knowing i we had frequency clash.
looks like i`ll have to heat it with a torch.
Thanks!
Old 08-08-2005, 07:27 PM   #4
Rapid Roy's Avatar
You really need to buy a new chassis. Especially with it being bent that much. When aluminum bends, it changes on a molecular level and becomes softer. You can bend it back and it will look straight, but it takes a much smaller force to bend it again.
If you really don't have the money to buy a new chassis, then you could bend it back. I have done it myself many times. The easiest way to straighten yours would be to use a vise and 2 rods. 3/8 or 1/2 round wood dowels would be ideal, but you can use almost anything. Put it in the vise like the following diagram. The straight line is the bent part of the chassis
o___o
O
When you squeeze the vise, the chassis will gradually bend back to straight. Don't try and go too fast. Take your time and you should be able to get it pretty flat. When you start using the chassis, you need to check the chassis after every few runs to make sure its still flat. Good luck
Rapid Roy is offline   Reply With Quote
Old 08-09-2005, 01:41 AM   #5
just replace the chassis and notch it up to experience. install a failsafe when racing where there is no radio impound.
even after straightening the chassis it still wont be straight(tweaked).
it looks like the bulkheads mount onto the bent area which is going to cause havoc in setup. the car may drive unpredictably due to the incorrect geometry relating to the chassis
onto greener pastures
stuff for sale associated 12r5 $175, team magic 1/10 pit bag $40, top racing pit bag $30, KO helios with spektrum module and 3 receivers $200, CEN CT5 $100 all are plus post
dangles is offline   Reply With Quote
Old 08-09-2005, 04:00 AM   #6
dct147's Avatar
Thanks for all your help guys,
i won`t be getting a new chassis yet, but will in time to come.
Rapid Roy, i don`t really get it. do u mean i use the vise across the front part of the chassis?
Old 08-10-2005, 03:25 AM   #7
Rapid Roy's Avatar
Okay here's a kinda hack sketch. Just go slowly and work a little bit at a time. I was able to get a fairly bent chassis almost perfectly flat. I doesn't stay that way if you start hitting stuff, but at least you can run.
Old 08-10-2005, 08:48 AM   #8
factory racer's Avatar
get him to pay for a new chassis....that is bullsh**t......it has happened to me and damn man it doesnt feel good.....id make him pay.....i would get a new chassis cuz like sum1 said on this post....the chassis will never be perfectly straight again...therefore your setup and car will always be "tweaked"
Mike.
factory racer is offline   Reply With Quote
Old 08-10-2005, 12:57 PM   #9
dct147's Avatar
Thanks for all your help guys.
have got a clearer picture of what to do with the vice already.
i`ll try straightening it up first till i can afford a new chassis.
I won`t get him to pay for a new chassis. no point as he`ll deny like he did. guess it`s part of the hobby.
Thanks again guys, really appreciate it.
Old 08-10-2005, 01:07 PM   #10
Rapid Roy's Avatar
You might need to just clamp the very tip of the chassis into the vise and pull the other end. You can also use the same method with the vise jaws open a bit and just use them as a brace while you bend. Just try different things to get fulcrum where you want to straighten. Good luck.
Old 08-11-2005, 07:35 AM   #11
dct147's Avatar
Thanks Rapid Roy,
Point noted. i`ll see what i can use.
Cen Matrix, Chassis bent? pinky2252s Nitro Off-Road 5 08-03-2008 12:11 AM
Bent Chassis XNXIXTXRXOX Nitro On-Road 3 07-10-2007 07:19 PM
bent chassis vandy0021 Electric Off-Road 15 06-14-2006 04:30 AM
Bent Chassis Sargios Nitro On-Road 8 03-14-2006 05:46 PM
Bent chassis? alucard13 Nitro On-Road 13 04-08-2003 08:36 PM
