Serpent 748 200mm nitro onroad kit >
Like Tree17Likes
Old 06-18-2019, 06:13 AM
  #1171
Dane's Avatar
Trader Rating: 25 (100%+)
Originally Posted by johansson.79 View Post
A quick question, at what diameter should i throw the tires in the trash?
/Daniel
around 54mm or less for me.
Dane is offline
Old 06-18-2019, 06:32 AM
  #1172
lil-bump's Avatar
Trader Rating: 85 (100%+)
56mm is my smallest for the rears
lil-bump is offline
Old 06-24-2019, 08:17 AM
  #1173
Ok, thanks. And the front 2mm less than the rear?
/Daniel
johansson.79 is offline
Old 06-25-2019, 01:23 AM
  #1174
dan_vector's Avatar
Trader Rating: 27 (100%+)
/Daniel
Yes. 2mm stagger with the fronts 2mm smaller than the rear.
dan_vector is offline
Old 07-11-2019, 05:44 AM
  #1175
savage24x's Avatar
Picked up a full RTR for $375... Comes in today! 748WC
What optionals should I order for medium-high grip asphalt? Any special onroad setup tools I need to get? Centax is out of stock...
savage24x is offline
Old 07-11-2019, 08:55 PM
  #1176
dan_vector's Avatar
To be honest the car doesnít need anything except maybe the alu servo horn for the steering. The car is great box stock.
Head over to the Serpent website and find a setup that suits your conditions but I used to run blue front springs pink rear springs. 800cst 3 hole all round. 2.5M in front diff and 80k in rear diff almost everywhere.
Old 07-11-2019, 11:49 PM
  #1177
Hey Dan quick question, I see that Dominic and other drivers used to run RCM-SS shocks on 748 and some still do on 750. Is there any benefit of using RCM-SS shocks? Honestly I don't like the big bore shocks they leak air from the x-ring no matter how much green slime I tried to apply. I also have a set of brand new RCM Short shocks (with 747 towers) from my 747 I can use, but 2 orings in each shock keep me thinking (too much firction maybe?).
I also bought the LF pistons for the bigbores but turns out the hole size is quite smaller and they dont fit the shafts well, so I went back to the original 3 hole white pistons.
Thanks!
cansoykal is offline
Old 07-12-2019, 05:20 AM
  #1178
Default Carb filter
Hey dan what carb filter you use to run on your .12 picco.
lighttravler is offline
Old 07-15-2019, 01:19 AM
  #1179
dan_vector's Avatar
xceed INS box.
Old 07-15-2019, 01:25 AM
  #1180
dan_vector's Avatar
Thanks!
the old shocks are longer thatís all really. You can run them on the 748WC with the old 748 or 747 shock towers from the original 748.
ive never had an issue with the standard shocks on 748WC or 750. Maybe Iím just lucky? Mine never leak at all.
the problem with the LF pistons and guides is that they swell up when in contact with oil and so the shock ends up getting bound up. The standard shocks and guides are better.
if you do have issues with the lower oring leaking you can add a shin to add a little more pressure to the oring to seal better. Another o ring would be too much.
Old 07-17-2019, 10:32 AM
  #1181
Thanks dan
