Old 07-30-2005, 03:54 PM   #1
charlesd's Avatar
Default Is there a way to fix chunked tires ?
I had a tire that was slightly chunked (hit another car ), so i cut a piece of rubber off of another dead foam tire and glued it to the other rim, then put it on the truer.
It looks ok but i'm not sure how long this will hold. Is there another method that will get good results. The tire was brand new.
charlesd is offline   Reply With Quote
Old 07-30-2005, 06:32 PM   #2
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
depending on the glue that you used, the propblem is that a thick clue will cause the tire to not grip as well and cause the car to be loose if it is on the back and push if it is on the front. I have found a couple glues that will work without having this issue, but it takes 2 days to dry completely and if you are going to race on them, you will need to let them dry for at least a week. The glue you need is: TRC #902 tire glue
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 07-30-2005, 07:43 PM   #3
I have fixed foam tires before with CA and i was using medium CA
Also i have seen some ppl put CA on the sidewall, my guess is that this prevents chunking, if this is the case what thickness CA and what are the adverse effects of this.
ATXPro4 is offline   Reply With Quote
Old 07-31-2005, 03:43 AM   #4
rcfoolz's Avatar
CA attacks the foam, causing it to harden. you can us CA but with the hardend spot on the tire will make you loose traction and also make the tire out of balance. The CA on the sidewall does help with the tire with chunking, but the reason most racers use it is to take side bite away from the tire as to not cause a traction roll
Cleaning Out Garage Sale TIRES TIRES TIRES MattOCM R/C Items: For Sale/Trade 5 01-15-2008 03:55 PM
fix bent rims & chunked tires rcfoolz Nitro On-Road 6 12-26-2005 09:01 PM
Chunked 10th scale tires (SAVE THEM) rcfoolz Nitro On-Road 13 05-23-2005 07:04 AM
Chunked Foam Touring Tires! rcfoolz R/C Items: Wanted to Buy 0 05-09-2005 08:54 PM
TIRES tires TIres, Ellegi or UFRA. bleach1 Nitro On-Road 51 06-01-2004 10:58 PM
