Xray NT1 2014 Specs >
Xray NT1 2014 Specs
Xray NT1 2014 Specs
Old 05-14-2014, 02:13 AM
  #61
harry5347's Avatar
After putting15 hours on it, it’s almost there. Gonna set it up tonight and it’s good to test run…can’t wait…
harry5347 is offline
Old 05-17-2014, 04:13 PM
  #62
congrats Harry !!!
I can´t wait my kit arrival... kkkkkkkk
kaka_lima is offline
Old 05-17-2014, 04:16 PM
  #63
Originally Posted by johnsen-dk
Hi
Well first of all I didnt race nitro last season and the season before I broke my last Engine at the last race , so new Engine. I chose the Reds because of 3 main things. The Nordic Reds importer is a old good friend , my new sponsor is dealing with him and the last thing , the Reds is 2/3 Price of a Nova. I felt it was quite easy to run in. Lots of power. I had my 2 gear set to early at the main this weekend , changed after 2 metres , and still the Engine pulled Hard at Low rpm.
good points John !!!
I already talked with my Reds Regional dealer... the reds price with pipe is less than a nova virtus without pipe here !!!
I have to think about it ...
Old 05-26-2014, 06:53 AM
  #64
Hi there.
I am intending to order my nt1 2014 as well as some spares. However, unable to locate the 2014 manual online.
Can anyone tell me if the arms, knuckles, uprights, belts, spurs, pulleys, pinions, one way adaptor (clutch system), and 2 speed housing are the same between the 2013 and 2014 versions of the NT1?
any option parts that I should consider?
thanks in advance.
sam
sammies is offline
Old 05-26-2014, 09:23 PM
  #65
Default Short (2013) or long (2014) shocks
Hi
What do you think about the difference in witch to use in what conditions? We race with free tyres,no additive. My opinion is to use the short ones. We raced this weekend and the car was just better balanced on the short ones
johnsen-dk is offline
Old 05-26-2014, 10:37 PM
  #66
Originally Posted by sammies
Hi there.
thanks in advance.
sam
Hello, except the 2-speed housing all your mentioned parts stayed the same.
greetings
thilo-alexander is offline
Old 05-27-2014, 02:35 AM
  #67
Bundy_Bear's Avatar
Hi
From Xray's press release for the RX8 they said Low Profile shocks worked well in high grip small diameter tyres. With new controlled tyres at a lot of events the longer shocks worked better.
http://www.redrc.net/2014/04/exclusi...x8/#more-79255
Bundy_Bear is offline
Old 05-31-2014, 11:42 AM
  #68
Team STPN's Avatar
Where in the US can I purchase the 2014??
Team STPN is offline
Old 05-31-2014, 05:45 PM
  #69
Bundy_Bear's Avatar
I take it the shaft is now shorter with the new mid mount on the 2014 spec car. Does it come with a light weight shaft or standard?
Old 05-31-2014, 09:00 PM
  #70
Its a hollow one
Old 05-31-2014, 10:47 PM
  #71
Michael_T's Avatar
Trader Rating: 52 (100%+)
Don't run the hollow main shaft
Michael_T is offline
Old 06-01-2014, 03:57 AM
  #72
Trader Rating: 32 (100%+)
For years, this has been a well known issue.
hobbs is offline
Old 06-01-2014, 04:50 PM
  #73
shiston's Avatar
Too much horsepower buddy
shiston is offline
Old 06-01-2014, 07:39 PM
  #74
Default Clutch
Anyone having problems with the spring of the clutch? Its 10mm long and if I adjust it to have 0,7mm preload the spring is fully compressed and all the coils tusch each other. Its like the spring is to long or the tread nut is to short. Advise please. We all use other spring in Denmark
Old 06-01-2014, 08:47 PM
  #75
Michael_T's Avatar
lol, actually the race is on Youtube, you see the moment when the gearbox rolls straight off.
