OFNA X3 GT SERIES
#196
#197
Pro parts from the X3 buggy that fit are.
Rear CVD's 41305
outdrive diff cups lightened 41404
aluminum Front,Front suspension holder 41406
aluminum Front,Rear suspension holder 41407
alum Rear,Front suspension holder 41408(but you have to gring down the side
tabs to clear the chassis)
Rear Toe plate 41409
Hingepin Inserts 41346
Suspension Hingepins 41312, two pins in a bag
Diff cross pins alum. 30774
Upper Aluminum rear chassis brace mount 41413
CNC rear uprights 41414
10 degree cnc front uprights 41533
12 degree cnc front uprights 41534
serrated wheel lock nuts 10994
Lt weight wheel hubs 41127
Rear CVD's 41305
#199
Kit comes with 2.5 rear block. Is a 3.0 available?
#203
R2,
I could be wrong but i dont think the rear toe plate on from the buggy will work on the GT. I have tried to swap them over already but because of the small piece that has the two holes in it to bolt to the bottom of the diff housing. On the Buggy that plate is raised from the bottom of the rear toe plate. On the GT that plate is flush with the bottom. I think the only way to be able to do it would be to find the bottom of the rear toe block down
#204
So far on my X3 GT i have completed the following mods
Rear 7075 axle carriers
Front 7075 lower hinge pin mounts and inserts
Front lower captured hing pins
7075 chassis braces front and rear
7075 castor blocks
I have put bearings instead of bushes in the steering
I will try and put bearings in the steering ackerman plate today
7075 castor blocks
#205
#206
R2,
The only one that does not fit on correctly is the RF hingeholder , you need to grind off the side tabs to sit into the chassis the Toe Plate fits though without any grinding, I have the set on my car now with the grinding to the RF.
#209
7075 castor blocks
7075 castor blocks
i notice that there is a slight difference in the recess hole between the 7075 alu mounts and the stock ones. i think some shaving is needed to the top of the plastic tab so that the hinge pin mount sits properly.
#210
Ok guys I have made a mistake on the rear hingepin holders, I just want to make clear they can fit but not without modification, into looking at the front end on what Fishcake said I did not see a gap on my front, so the is no issue there, however the rear had a gap and as was mention before in a post that the rear toe plate might not fit correctly was right, there is a gap there on the rear as the plate sits lower that the chassis and brings it up.
Here's the mod to make it work, you need to grind down both hingepinholders, for the rear-front the two tabs on the outside, for the rear toe plate you need to grind down the insert tab to the gearbox and turn it upside-down, this in turn will level out you rear arms more, giving you less anti-squat which you really don't need in On-road, so this is good but the dremel needs to handy when putting them on.
I will go out to HCRP again this Sat and do some more running, my car is the new X3-e coming soon but this will also work on the NItro version to.
