Old 02-11-2014, 04:47 PM   #1
Default 190mm/200mm question
Does this reference the wheelbase or the width of a vehicle?
Phins Fan is offline   Reply With Quote
Old 02-11-2014, 05:14 PM   #2
azeroth's Avatar
Trader Rating: 20 (100%+)
width
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 02-11-2014, 07:24 PM   #3
I ask as I picked up a RS4 3 Evo. My lhs has a complete set of MIP shiny axles for a rs4 200mm which is the width of my 3 evo. Even though they aren't labeled as rs4 3 evos I wanted to know if they were labeled 200mm if they should fit? Complete front and rear in the clearance bin for $20 new seems like a no brainer to me
Old 02-11-2014, 07:25 PM   #4
ThePanda's Avatar
Trader Rating: 65 (100%+)
it is adjustable by running different offset wheels though. so a 190mm chassis could use a 200mm body if you ran 5mm offset wheels on each side. (though you would probably have to run just 3mm on each side, as 5 isn't a standard that i know of. goes 0mm, 3mm, 6mm, 9mm, 12mm (higher offsets usually used for drifting. )
ThePanda is offline   Reply With Quote
Old 02-11-2014, 07:29 PM   #5
ThePanda's Avatar
they should fit, but the bones might be a little short though. (usually the extra 10 mm is made up with larger arms, which requires longer bones)
Old 02-11-2014, 08:48 PM   #6
blis's Avatar
Your hubs will need to be extended 5mm each side, as it's from the outdrives on the diff to the wheel hub that determines the length of the axle/dogbones/cv
So if you can widen the hubs on the car, then remove the dogbones and compare them to the ones in the store, eg +5mm
Dont forget all diffs have different widths, the wheel hubs and outdrives on the diff can vary so it's not just a matter of 200mm axles.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 02-13-2014, 03:36 PM   #7
YR4Dude's Avatar
Trader Rating: 44 (100%+)
It should fit. The only difference between the RS4 2 and the RS4 3 nitro is just the drivetrain.(shaft vs belt) Both uses the same suspension components.
However, if you're asking about the RS4 2 electric vs RS4 3 electric, that is a totally different ball game.
YR4Dude is offline   Reply With Quote
