Old 07-26-2005, 01:03 PM   #1
MikeBtc3's Avatar
Default STS Motors
I just got a sts motor and i was wonderin how long does it normally take to break this motor its a Sts Dragon D3R .12
MikeBtc3 is offline   Reply With Quote
Old 07-26-2005, 01:36 PM   #2
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
D3r is a pain to break in, at least mine was. It requires at least 20 tanks before it stops pinching.
I ran it for 3 tanks (125cc tank) with propeller at around 85c, 10 tanks at 90-95 and then just leaning out to around 110-115c which is normal operating temp.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 07-26-2005, 02:12 PM   #3
gonzoY5's Avatar
Why not go to the STS thread to find out more info
http://rctech.net/forum/showthread.p...00#post1719800
gonzoY5 is offline   Reply With Quote
Old 07-26-2005, 02:15 PM   #4
why just not be a jerk and help
by the way, i cant find the 42t gear for my m18... hopefully i can so i will be there on wednesday
Joe Chaplow is offline   Reply With Quote
Old 07-26-2005, 02:21 PM   #5
gonzoY5's Avatar
LOL...because NO ONE RUNS a STS here in Miami JOEiwishihadaMUGEN
Old 07-26-2005, 02:30 PM   #6
i do, its called a mrx-4....so
Old 07-26-2005, 02:32 PM   #7
nsxshogun's Avatar
Send a message via AIM to nsxshogun
MIKE MIKE...............................
Don't forget to get some cold plugs.
nsxshogun is offline   Reply With Quote
Old 07-26-2005, 02:34 PM   #8
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
2 liter of fuel. Your not supposed to lean it before that.
Artificial-I is offline   Reply With Quote
Old 07-26-2005, 02:38 PM   #9
nsxshogun's Avatar
I'm still trying to figure out how to lap the piston. I here that the engine is hard to breakin and that should ease it up alot.
Old 07-26-2005, 02:40 PM   #10
Moderator
I only know of lapping cpu's to get them to have a flatter surface.
Lapping was done that way with a fine grit sandpaper and a piece of glass as its perfectly flat. Im thinking lapping a piston would get the compression to go lower which you could get from adding a shim.
But maybe there is another way to lap the piston.
Old 07-27-2005, 02:42 AM   #11
Hesky's Avatar
I'm pretty sure lapping is just the name used when you are trying to get 2 surfaces to get a perfect fit. I remember a friend telling me he used to use a method called helical lapping which basically was a rotation and reciprocation movement of the piston to get the right fit of the liner/piston on his boat engines, to speed the process up he used very fine lapping compound.
I guess when we break in our nitro engines we're simply lapping the piston an sleeve in a reciprocating movement only.
Hesky is offline   Reply With Quote
Trinity Co27 Monster Stock Pro Motors & Reedy Neo 2* BL Motors For Sale Leodis R/C Items: For Sale/Trade 17 05-11-2007 06:03 PM
GM Brusless ESC & Motors, LRP Charger, MM Motor Master, Yokomo Motors tones Australia For Sale/Trade 5 05-08-2007 07:22 PM
MOTORS MOTORS MOTORS EPIC C2,INTEGY BLUE ATLAS 19,AN MORE DENNIS STORTI R/C Items: For Sale/Trade 18 01-06-2007 09:44 AM
Mod Motors, Stock Motors, Rubber Tires and a Novak Syns. Module Team Speedy R/C Items: For Sale/Trade 1 07-13-2006 07:28 PM
stock motors . mod motors - feedback needed Babylou Electric Off-Road 4 05-07-2004 05:00 PM
