Old 07-26-2005, 12:55 AM   #1
silacomalley's Avatar
Send a message via MSN to silacomalley
2WD drive verses 4WD?
On a touring car, which is better, 2WD or 4WD? Silly question probably, but I don't know what the pros & cons of each are.
silacomalley is offline   Reply With Quote
Old 07-26-2005, 05:57 AM   #2
Four wheel drive is always better. More traction, especially in low grip conditions. Two wheel drive is easier on tires.
I don't know of any touring cars that come in 2wd, but there was a 235mm 2wd class that may still be popular in Europe. In the US 2wd is all but gone.
jiml is offline   Reply With Quote
Old 07-26-2005, 09:02 AM   #3
Jye
if drifting keeps up in sure 2wd will come back.
Jye is offline   Reply With Quote
Old 07-26-2005, 09:41 AM   #4
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
4wd will pretty much destroy 2wd in all conditions. If you want 2wd effect you can always disconnect a belt. Front or Rear , depending on what kind of car you want to drive.
Artificial-I is offline   Reply With Quote
Old 07-26-2005, 10:24 AM   #5
JLock's Avatar
2wd will help to make you a better driver due to having to use more throttle control (discipline) and radio setup. Yes, 4wd is faster due to putting the power to all four wheels but most drivers don't learn throttle control discipline due to being able to power out of situations because of the 4wd. Personally, I became a better driver running 2wd 235mm classes a couple of years back locally when 2wd was still the "in" thing. It taught me alot about what I mentioned above, especially proper car setup for track and conditions.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 07-26-2005, 04:15 PM   #6
sonicboom141's Avatar
Send a message via AIM to sonicboom141
drifting
sonicboom141 is offline   Reply With Quote
Old 07-26-2005, 04:45 PM   #7
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
especially running the 1/12th scale
Old 07-26-2005, 10:49 PM   #8
JLock's Avatar
Yes, your assessment on that is correct as well. With 1/12th scale, most racers develop quicker reflexes and reaction times over those of us that run just 4wd. 1/12th scale help one to develop into a more precision driver.
Texas 5
ib3600 verses ib3800 for off-road stock? woodytx Electric Off-Road 9 04-10-2006 09:55 PM
Belt Drive versus Shaft Drive SUNA Nitro On-Road 20 03-28-2006 09:04 PM
Belt drive verses shaft driven? silacomalley Nitro On-Road 3 07-27-2005 12:26 PM
Fantom verses Trinity 27T stock motors blueskieshlg Electric On-Road 2 01-28-2005 07:33 AM
Belt drive versus shaft drive...pros and cons of each? AttackDonut Rookie Zone 21 01-02-2005 05:23 PM
