Old 09-09-2002, 08:34 AM   #1
MX3
Default Base settings for OS CVR .12
anyone know what's the factory setting for the high end/middle mixture for this engine?
thanks
MX3 is offline   Reply With Quote
Old 09-09-2002, 08:43 AM   #2
After tuning, mine usually runs between 1 1/2 to 2 turns out on high end and flush on low-end with rotary carb. I think the slide on low-end runs just in from flush.
ronin8451 is offline   Reply With Quote
Old 09-09-2002, 01:39 PM   #3
MX3
thanks ronin8451
will try that the next time i go to the track
Old 09-21-2002, 01:12 AM   #4
hi guys!!
wat do you mean by flush??
i am also trying to tune my 12 cvr but cant seem to get it right, real beginner here.. thanks
bern is offline   Reply With Quote
Old 09-21-2002, 03:51 AM   #5
Send a message via AIM to ZER01
Bern, he means the end of the low-end needle is flush with the side of the carb. I own a 12CVR/slide carb. I beleive "break-in" settings are 2 out on the high end needle. I left my low-end needle like it was during break-in and after break-in I started leaning it out(low-end) to get some punch. It's now 90 degrees in from factory settings(like it was when it was in the box). Then just tune your idle stop screw to get a good idle. If you screw out the idle stop screw to far the car will have a hard time idling.
ZER01 is offline   Reply With Quote
Old 09-21-2002, 04:42 AM   #6
so you mean the low end needle is level with the edge of the screw hole and after running in, you turn 90 degree in?
it seem my idle screw is quite hard to reach, me using v1r. the beam is like obstructing the needle..
thanks for the reply!!
Old 09-21-2002, 09:35 AM   #7
asd
Send a message via ICQ to asd
yup
asd is offline   Reply With Quote
Old 09-21-2002, 04:41 PM   #8
rcruv's Avatar
Try here.
http://www.osengines.com/manuals/index.html
rcruv is offline   Reply With Quote
Old 09-21-2002, 11:36 PM   #9
thanks for the help guys!!
will try it this evening if i got the time, as a beginner, got to learn lots of stuff from you guys.
hope i will be able to get it running good.
happy rcing!!
Collari XS.21 600 motor base settings hassro Nitro Off-Road 0 08-23-2008 05:08 AM
ninja jx.21 base settings? Chedster Nitro Off-Road 4 08-11-2008 05:02 PM
Base needle settings for 427 badaml Nitro Off-Road 3 10-15-2007 08:42 PM
PS base settings Hrdluck13 Electric Off-Road 3 11-13-2006 06:05 PM
Base needle settings (MT-12) skibum989 Nitro On-Road 8 04-09-2003 02:04 PM
