Old 07-18-2005, 05:03 AM   #1
miks vones2's Avatar
Default 3D cltch adjustment
anyone know a quick and easy way to make adjustments to he kyosho 3D clutch (like on the voneRR) ???
thanx
miks vones2 is offline   Reply With Quote
Old 07-18-2005, 06:58 AM   #2
jrabbito's Avatar
what adjustment are you talking about? Gap, Endplay, Spring?
Try this article..
http://www.cefx.net/tips/nitro/clutch/index.php
john
jrabbito is offline   Reply With Quote
Old 07-18-2005, 11:40 AM   #3
fraz's Avatar
Send a message via AIM to fraz
thanx
Josh's article is good. Do you have any specific questions about this clutch? Myself and a lot of other Kyosho racers here use this clutch and we can help. If you are just looking for a quick way to adjust your clutch, this tool is cool.
http://www.happytimehobby.com/catalog/images/ys1002.jpg
I have one in my aresenal, though I did have to modify it a bunch to get it to work on our clutch bells.
fraz is offline   Reply With Quote
Old 07-18-2005, 07:27 PM   #4
thanx for the response, i will check out those articles when i get home.
i am not new to nitro racing, but am new to this clutch system.
i am just in the process of running in a new sirio s.12 and the clutch wont engage at low enough revs for me to run the motor at low spped for the first couple of run-in tanks. i dont want to rev the motor high at this stage.
i have set the spring as per the manaul, but now need to back it off so it will engage sooner.
i was just after a tip so i can make this adjustment quickly to suit my track ect witout having to remove the clutch bell.
thanks again.
Old 07-19-2005, 01:51 PM   #5
fraz's Avatar
You can use a tool like the one I posted or you may be able to stick a 1.5mm allen wrench in the side of the clutch bell and turn the flywheel.
If the motor is too rich it will not engage the clutch properly. I broke in a couple of Collari .12s this weekend and they were pretty rich with factory needle settings. These motors are based on the Sirio so you may need to lean the top end out a little and the clutch should start coming in.
what adjustment? peahbeez Electric Off-Road 2 05-08-2005 04:16 PM
TL-01 adjustment robborc Electric On-Road 3 02-15-2005 08:03 PM
Timing Adjustment, What's it do? LosiFromHell986 Electric Off-Road 4 02-08-2004 04:46 PM
Steering adjustment ? DesperAuto Rookie Zone 6 07-17-2003 12:49 AM
Brake adjustment G-16 Rookie Zone 2 02-23-2003 08:16 PM
