need help with nitro rs4 72516 2 speed
On the HPI site you can download the manual. If it is not listed in the manual (2-speed was an option with older models) you can find the manual of the gearbox or just download te manual of the RS4-3-SS models (standard with gearbox).
The SS models are self assembly kits
The way how the gearbox works is the same.
If it doesn't have the screw, chances are the spring and ball that go in there are missing as well I'm about 90% sure that the screw, spring and ball from the traxxas 2 speeds will work. I know they're mostly internal 2 speeds except for the 4tec, but I believe they will work.
