Old 07-12-2005, 08:23 AM   #1
Default can i fitt 190mm shells on a 200mm chassis?
sorry for all these stupid noob questions but im just trying to get a know how. ive seen a few shells that i like but theyre in 190mm or 230mm width and i have a 200mm car. can these shells still fit??
what would it take to fit the 230mm shell?
golf4 is offline   Reply With Quote
Old 07-12-2005, 09:36 AM   #2
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
I dont think you can fit a smaller on a bigger body. But you can do a bigger on a smaller. Not sure about the 235 though on the 200.
I know electrics can put 200mm on their 190. Thats all I know that can be done otherwise someone else will have to answer that.
Artificial-I is offline   Reply With Quote
Old 07-12-2005, 09:43 AM   #3
i think some cars have conversion kits to go bigger to 235mm. theoretically, you need to lengthen your car on each side by 17.5mm. so if you kept the car stock and put a 235mm body on it, you would just have a 17.5mm gap on both sides... it would probably work, just not be too efficient.
Joe Chaplow is offline   Reply With Quote
Old 07-12-2005, 11:01 AM   #4
duneland's Avatar
Best to stick with 200mm. There are plenty to choose from & you will compromise your cars handling if you go to any other size. You could narrow your car up a bit to run the 190, but why bother?
duneland is offline   Reply With Quote
Old 07-12-2005, 11:13 AM   #5
Trader Rating: 16 (100%+)
190 on 200 chassis...sure why not, if you just use those for LOOKS only....remind me those low-rider truck, dropped the suspension to ground, and with hugh offset of their tires so they can ruin their axles....
Old 07-12-2005, 12:56 PM   #6
Rapid Roy's Avatar
In general, the 190mm bodies will fit a 200mm car. If you use 24mm tires and wheels with zero offset and make your car as narrow as you can. The best way to check is to put the tires and wheels on your car and measure across the front and rear. Take the tape measure to the LHS and measure the body you want to get. I know many MFG's make there bodies quite a bit wider then the actual track width because the additional width increases the available downforce.
Rapid Roy is offline   Reply With Quote
FS: painted 190mm shells J-PaP Australia For Sale/Trade 2 03-04-2008 10:26 PM
200mm unpainted lexan touring shells for sale $20 I'm_Serious Australia For Sale/Trade 7 03-04-2008 06:56 PM
BNIP Mazda 190mm Shells Corey The Great Australia For Sale/Trade 6 07-08-2007 03:38 AM
190mm Body shells creamsodauk Electric On-Road 5 06-30-2006 06:09 AM
is it 190mm or 200mm? lee82gx Nitro On-Road 12 10-07-2003 02:18 AM
