Old 07-08-2005, 04:40 PM   #1
Default R40 rear diff fluid, leaking
Hello - new member here. I have been running a Savage .26 for over a year and a RS4 18ss for about 4 months. I just got an R40 kit. I am installing this motor with an SG shaft. I am going to use it with this pipe. I am painting this body and this body.
My new R40ís build manual says to use grease in the rear diff but I figured that silicon fluid would be better. I filled the rear diff up with 5,000 fluid and put it together being very careful to not damage the gasket. Now that the diff is together I can see a little fluid leaking out where the two halves meet. The fluid is making its way onto the teeth where the belt goes.
Are you guys running silicon fluid in the rear diff? This minor leak has me concerned.
rossb is offline   Reply With Quote
Old 07-08-2005, 04:54 PM   #2
Fsturbo15's Avatar
Send a message via AIM to Fsturbo15
Try asking in the R40 thread, its a very long thread, you can find a lot of answers there if you use the search this topic feature.
Obviously most of the guys in the thread have R40's.
Just incase you cant find it (Its the first thread on this page atm, here it is
http://rctech.net/forum/showthread.php?t=22061
Fsturbo15 is offline   Reply With Quote
Old 07-08-2005, 05:12 PM   #3
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Please do go to the R40 thread -- but your short answer is -
Use " blue permatex" on the diff cases to stop them from leaking. Also - the grease depends on traction. For starters, don't use any oil. Just a light dap of grease to provide some lubrication. This will provide max rear traction in the rear until you need more power. Hope that helps and I'll see you in the R40 forum soon..
JAG Racing is offline   Reply With Quote
B4 Rear shocks leaking oil. Help needed yokfans Electric Off-Road 38 04-02-2009 11:44 AM
diff fluid? zman_99 Monster Trucks 5 01-27-2008 01:56 PM
mugen diff fluid lot FS pwnzor R/C Items: For Sale/Trade 3 10-03-2007 12:42 PM
Front & Rear Diff fluid changes, how it affects steering? Cain Monster Trucks 11 08-01-2006 02:34 PM
Diff. Fluid skaterdawg2000 Electric Off-Road 1 01-11-2004 03:58 PM
