Turning problem with receiver help?
Hi guys my new nitro car was working like a charm I could turn left to right rapidly until my friend crashed it now when I try turning rapidly the receiver light shuts off for a few seconds then come back on I can't turn rapidly please help I'm I'm new to nitro cars. Btw
Does the Carb/Brake servo work? May have to change Steering servo. After crashing Steering servo take a pounding. Especially RTR models. Change to a HS/HT/ BB/MG servo. Reverse the Steering & Throttle servos on the RX, If the Throttle acts like the steering, Steering servo need to be replaced.
Switch them to normal plugs on RX. Does the throttle work as normal, leaving the steering disconnected from RX. Your steering servo has shorted out internally. Replace it with a good HS(Hi-Speed), HT(Hi-Torque), MG(Metal Geared), BB(ball Bearing) Servo. Futaba, Airtrionics, Savox, Hitec. Your LHS can help you. depending on your wallet can stand.
Re bind receiver
