Old 08-02-2006, 06:29 AM   #1471
Orfeous's Avatar
Send a message via ICQ to Orfeous Send a message via AIM to Orfeous Send a message via MSN to Orfeous Send a message via Yahoo to Orfeous
Old news
Originally Posted by Doug M
The following new optional parts for the 960 just arrived in the USA. Your Serpent dealer should have these parts in stock very shortly.
Servo Saver Set with Adjustable Ackerman
http://www.mytsn.com/products/desc.asp?prid=4339
Tank Cap AFL + O-Ring Set
http://www.mytsn.com/products/desc.asp?prid=4336
RCC Shock Absorber Tool
http://www.mytsn.com/products/desc.asp?prid=4321
Orfeous is offline   Reply With Quote
Old 08-02-2006, 08:29 AM   #1472
Bob Malphurs's Avatar
Talking
Hey Serpent guru's....I'm looking for the "perfect" clutch setup. Can't seem to get it set for my sons (Robbie) 960! He wants it to hit hard out of the turns but I just haven't found the right combo of spring, end-play, etc. When I do get it to hit hard enough it overheats and fades out. I've looked in TSN but haven't found anything.
Bob Malphurs is offline   Reply With Quote
Old 08-02-2006, 08:36 AM   #1473
Hit the wrong button and it posted before I was done talking!.....
Anyway, if someone can point me towards an article on the clutch or post it here I'd appreciate it!
BTW, does anyone use the "Tommy Nut" setup anymore? I'm sure Doug M will remember it
Old 08-02-2006, 08:52 AM   #1474
Trader Rating: 4 (83%+)
Bob:
Here are some things you can try..
First you can check what gears and pinions you are using maybe you can a little more punch with changing the gears..
Here is what i use on my 960 and have great punch exiting the corners hope this helps..
clutch bell 16/19 spur gears 45/50
903199-serpent ptfe machined flyweights/these can be used in a couple of ways,(1)like the regular flyweights on the pin,(2)off the pin wich would be a little more aggressive,(3) Off the pin plus add a set screw to one of the holes to make it a little more aggressive than #2..
909520-Centax II / III spring 1.8 (10mm)
i use 0.70 play and 1.30 clutch spring..
Roniel_R is offline   Reply With Quote
Old 08-02-2006, 09:50 AM   #1475
Orfeous's Avatar
how many things is possible to do on the 960 to reduce the heavy weighted 960?
Old 08-02-2006, 10:10 AM   #1476
Thanks Roniel.....I'll order those flyweights today.....to use off the pins, does that require cutting that part of the flyweight off?
Been waiting for that shock tool.....ordering that as well!
Old 08-02-2006, 10:11 AM   #1477
aaalp's Avatar
Send a message via ICQ to aaalp Send a message via MSN to aaalp Send a message via Yahoo to aaalp
Post
Here are tips from Josh --> http://www.cefx.net/tips/
Here are tips from Glenn --> http://www.mytsn.com/publ/publlist.asp?cid=869&ccid=9
Here are some additional tips for 960 from Daltonshop: http://www.daltonshop.com/tips_tricks.htm
I hope it helps.
aaalp is offline   Reply With Quote
Old 08-02-2006, 10:13 AM   #1478
Orfeous:
Serpent makes a couple of lightweight parts for the 960,on my 960 i have alot of optional parts that you replace from plastic to alluminum as optionals plus alluminum screws and my car is really light not under weight but very close,i also use a lipo reciever pack wich also reduces alot of weight ...
Old 08-02-2006, 10:23 AM   #1479
Bob:
It does not require cutting at all the flyweights are all ready for just dropping them into the flywheel,first try it without the set screws,and if does not kick as hard as you would like it then try the set screw,let me know how it works out for you ....
Old 08-02-2006, 10:25 AM   #1480
I see from aaalp's link (glenn's) how the weights look off the pins....just couldn't see it in my minds eye!
Old 08-02-2006, 11:07 AM   #1481
Orfeous's Avatar
Ok, the 960 i am going to buy as i said before has all options installed allready so i think the car is allready lightened? i think he has changed the screws to alluminum too. But i dont have a lipo reciever pack
Why is the car heavy from the box?
Originally Posted by Roniel_R
Orfeous:
Old 08-02-2006, 11:51 AM   #1482
Perez's Avatar
Hey guys,
I need help finding a link or PDF for a blank 960 set up sheet. I tried serpent usa's website and serpent.com . thanks!
Perez is offline   Reply With Quote
Old 08-02-2006, 12:09 PM   #1483
Doug M's Avatar
Default Blank 960 set up sheet
Originally Posted by Perez
Hey guys,
I think you will find the 960 blank set up sheet and much more at this link.
http://www.mytsn.com/products/downlds.asp?prid=4090
Doug M is offline   Reply With Quote
Old 08-02-2006, 01:02 PM   #1484
Taner's Avatar
Hi Guys,
Has anyone the overdrive ratio for 960s? Or do u guys now any links?
thnx
Taner
Taner is offline   Reply With Quote
Old 08-02-2006, 01:24 PM   #1485
Doug M's Avatar
Default Overdrive Ratio
Originally Posted by Taner
Hi Guys,
thnx
Taner
You can use the same chart as the 950R. Below is the link for downloads.
http://www.mytsn.com/products/downlds.asp?prid=3277
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
