Old 02-20-2006, 09:17 PM   #736
Originally Posted by C Verano
I ran the short wheelbase at the national with a 2018 and a short conical. Maybe you can try a shorter header and play with gearing and the clutch to make the bottom end you are looking for.
Chris, what does a short wheel base do for the car? I've never tried it.
going4#1 is offline   Reply With Quote
Old 02-20-2006, 09:51 PM   #737
C Verano's Avatar
When I shortened the car it seemed to give the car more steering.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 02-20-2006, 11:57 PM   #738
Default Winter Nats - Serpent cars dominate both A-mains
Wow, did you see the results for 1/10th on mytsn? 5 710s in the A-main. 4 960s in the 1/8th A-main. Nice way to start off 2006.
Old 02-21-2006, 06:59 AM   #739
Azman Azam's Avatar
I use the 6 fin with a JP and you're right, there isn't a lot of space left.
Unlike 1/10th I've haven't seen a lot of variation in pipes for 1/8th on-road. For off-road, sure, but on-road. Not really. Anyone else?
I guess the questions is, are you willing to give a bit of handling for the added power? Does the shortened wheel base really help a lot? For short tracks I found removing the side stiffeners helps with handling. Could that help you?
Sadly the track that i'm at is really technical with one long sweeping straight.. and I've tried the original short header with the 2018 pipe + short wheel base. The car was awesome.. handled very well.. Just lagging a bit of bottom end punch.
Tried multiple gearing & various clutch setting.. still not as good as the 7 fin header.
What if I grind say... 2mm of the tuned pipe head (where the grub screw sits). Is that advisable?
Cheers.
Azman Azam is offline   Reply With Quote
Old 02-21-2006, 07:08 AM   #740
Azman Azam's Avatar
Hi all,
Another problem i'm having is inconsistent braking..
After a long straight ill need to brake hard (and long) for a hairpin turn at my track.. Usually when the braking power is not enough I'd increase the brake (EPA).. the problem is at some slower part of the track where braking is required the car would seem to loose out is rear end with a tap of the brake's. Make's me kinda nervous to push the car all out. I think a few of the 960's here are having that problem.
Currently using the standard disk brake with the optional brake pad. Any comments?
Cheers
Old 02-21-2006, 10:22 AM   #741
Freelander7
Guest
Posts: n/a
Hi, are the Jaco Nitro shoes tires (1/8th scale) on sale yet? I cant seem to find them anywhere and im going to need to order tires soon as the season is starting again..!
Old 02-21-2006, 10:27 AM   #742
Freelander7
Guest
Posts: n/a
Cheers
Hi, what rear downstop settings are you using? Try changing them to 9 or even 10 depending on how severe your finding the problem.
Old 02-21-2006, 11:02 AM   #743
Default Tyres and Engines
Congrats to all the Serpent drivers at the Winternats! All classes showed some serious performance and Morganti dominated 200mm.
Are the new Jaco/Serpent wheels now available in the US and Europe?
Also is there any more information about the Massimo Fantini engine that will be carried by Serpent?
Kendall is offline   Reply With Quote
Old 02-21-2006, 11:08 AM   #744
C Verano's Avatar
I think Serpent just received the 1/8 scale shipment of Jacos right before the Winternats. I suppose they would be shipping out to dealers now or very soon.
Maybe Doug or Paolo will jump in and asnwer the question on the Fantini engines.
Old 02-21-2006, 03:41 PM   #745
who's car is it?
is someone know the driver's body color ?
i know paolo run with white and black body,Bertin with yellow and black...but Salven,Swauger,and other finalist i don't know??
nefastseven is offline   Reply With Quote
Old 02-21-2006, 05:31 PM   #746
Freelander7
Guest
Posts: n/a
Hi, I was wondering if anyone would be able to tell me what bodyshells were being used in the A-main? Particularly the serpent drivers..Paolo,Scotty,Barry,and Steven.
There seems to be a lot of confusion over bodies, apparently a lot of new bodys were used.
Old 02-21-2006, 05:48 PM   #747
We already receive the Jaco's and we are almost out of stock
New order are on the way.
About the Mega MF line, will be released shortly
Paolo
Paolo M is offline   Reply With Quote
Old 02-21-2006, 05:58 PM   #748
Originally Posted by nefastseven
who's car is it?
This is Mark Harrison 960. I run Black and white on the practise bodies and my scheme on the race bodies. This is my shceme for sedan. The 1/8 scale is very similar with same colors
Paolo
Old 02-21-2006, 06:00 PM   #749
Me, Scotty and Barry where using the Serpent EV3 Lola (#1757). Steve was using the Kyosho body
Paolo
Old 02-21-2006, 09:23 PM   #750
Cheers.
How much space is left for the screw if you take off 2mm? Don't get rid of the hole for the muffler holder. You need that. Instead of using a screw to hold the muffler to the holder, thread the holder through the end of the muffler and use a linkage stopper on the end of the holder. Use a second stopper or some fuel tube to make sure the muffler doesn't go too low and scratch the ground.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
