Old 02-04-2006, 03:59 PM   #586
Originally Posted by nefastseven
is the Filler-plate carbon a good optional part?
is it possible to put it on a classic chassis?
I think it is better because makes the car stiffer and in any case is an additional tuning device (High bite track needs stiffer chassis) It is not possible to install in the std chassis
Paolo M is offline   Reply With Quote
Old 02-04-2006, 05:33 PM   #587
Freelander7
Guest
Posts: n/a
Originally Posted by Paolo M
Jaco has just started to glue their rubber in our latest OEM wheel for both sedan and 1/8 scale. We have tested the tires since November already in different tracks, and in all we had more side and forward traction in the rear, with really good steering with very good overall balance (i had almost the same feeling with the tires we where using before, but with the rear sliding too much)
I find the lap times close (just a little bit faster) but a lot more consistant.
Not sure if anyone has seen this http://www.mytsn.com/forums/forum.as...lo=1&sm=0&fi=1
Thanks Paolo, im looking around for the tires but its not easy getting a shop that will ship them to Ireland! I just want to get 1 or 2 sets to comapre them to what im running.
Just to make sure, as i know these tires have only just been released by jaco, would you be able to give me a link some pictures of the rims they are on and the proper name for the tires?
Btw, what tires were you running before that you were comparing them to..?
Old 02-04-2006, 06:00 PM   #588
GRP Ellegi
Old 02-04-2006, 06:58 PM   #589
C Verano's Avatar
Default Jaco
I tested the Jacos today. The tires worked just as described by Paolo. I ran 38's today at my local track Revelations, and the car was very stable on the Jacos. I ran them back to back against the Ellegi and the car was definitely more planted. On the Ellegi the rear end of the car wanted to step out a little but with the Jacos it was stuck. I let a couple of other 960 drivers try them and they had the same results.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 02-04-2006, 07:04 PM   #590
richey's Avatar
Send a message via MSN to richey
Chris,
Did Garen make it out there today?
Silver Bowl Raceway Operator
www.TeamTaylorRacing.net
Byron's Fuel, Airtronics
JoshStevensFoundation.org
richey is offline   Reply With Quote
Old 02-04-2006, 07:20 PM   #591
C Verano's Avatar
Originally Posted by richey
Chris,
Did Garen make out there today?
Yup..
Old 02-04-2006, 08:05 PM   #592
captian's Avatar
sounds good to me thanks chris for the feed back
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 02-04-2006, 09:17 PM   #593
C Verano's Avatar
No problem..Once you get your hands on the Jacos, you will be very happy with them.
Old 02-05-2006, 06:49 AM   #594
M7H
M7H's Avatar
and as I mentioned in the TSN topic
If the tires are made in America, they just might be better priced for us guys here in Europe.......
Serpent
M7H is offline   Reply With Quote
Old 02-05-2006, 02:07 PM   #595
if i make one in lexan or some thing in a flexible matter,is it a good idea to protect the front belt and steering system from stones and other large debris?
nefastseven is offline   Reply With Quote
Old 02-05-2006, 02:13 PM   #596
i have a question about hudy set-up system
i have hudy in acrylic plastic for mrx-3,can i use it with 960??
someone says it's not possible and other says it's possible
Old 02-05-2006, 03:10 PM   #597
C Verano's Avatar
It should work on your 960.
Old 02-06-2006, 04:11 AM   #598
i have my 960 this morning
i'm building it and i have a question Servo saver horn #2 or #1 gives the car best turn...
i'm looking for that in the set up book,but i don't find where it's written...
Old 02-06-2006, 04:29 AM   #599
i'm building it and i have a question Servo saver horn #2 or #1 gives the car best turn... I'm looking for that in the set up book,but i don't find where it's written...
I looked, and the S960 Setup Book does not have information about steering Ackermann. I went to the new XRAY T2 Setup Book, and found this information:
"If the car steers well off-power but pushes on-power, then use more Ackermann effect (straighter linkages) and decrease your transmitter EPA/dual rate."
"If the car steers well on-power and pushes off-power, or if you can hear the front inside wheel chattering at mid-corner, then use less Ackermann effect (more angled linkages)."
I hope this helps.
GlennCauley is offline   Reply With Quote
Old 02-06-2006, 05:18 AM   #600
M7H
M7H's Avatar
Possible with a XRAY car, difficult to hear with a 960....
Serpent
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
