Old 01-05-2006, 07:38 AM   #466
C Verano's Avatar
Originally Posted by Freelander7
Ive been driving an evolva all year and when the 960 came out changed back to serpent. However i dont know what affect changing the ackerman holes on the 960 has. Would someone be able to explain it please? Like the differences of e.g. no.2 servo saver and which holes have what affect?
Thanks!
There was a discussion on that back on page 10.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 01-05-2006, 08:10 AM   #467
Freelander7
Guest
Posts: n/a
Old 01-05-2006, 08:40 PM   #468
Default Pegaso Mexico Race January 19-23
Paolo and friends...
If you can give me any setup information and or engine tuning suggestions for a stock ZX in my new 960 for this race in Mexico I would greatly appreciate it. About 10 of us from Texas are flying down for the race and I will be running my new 960 for the first time. Any help, ideas, or information would be greatly appreciated... My first trip to the high altitude of Mexico City area.
Doug Darby
Secretary - Radio Control Race Cars on North Texas (RCRCNT)
Doug Darby is offline   Reply With Quote
Old 01-05-2006, 10:29 PM   #469
C Verano's Avatar
Doug Darby
Doug,
Not sure if you've seen it already but you can download Paolo's Ft Myers set up here..
http://www.mytsn.com/products/downlds.asp?prid=4090
Chris
Old 01-05-2006, 10:39 PM   #470
C Verano's Avatar
Id never have guessed, i pulled the qoute out of mid air mate... i read it, just dont fully understand.
Anway does anyone have anything to add to it that could maybe help? thanks.
I usually run the #2 ackerman in the outer holes for the most steering. If you move to the inner holes on the arm it should take steering away.
Old 01-06-2006, 01:39 AM   #471
Default 2 speed shaft
I just left the track, frustrated knowing that my 2 speed shaft broke into 2 while I was breaking in my new engine. My Evlova 2 speed shaft will bend a little bit but never snapped into pieces. The good thing is it is just a practice day, if it broke during a race I will be putting the car into the garbage.
Originally Posted by C Verano
Not sure about them being a recalled item...
slide_228 is offline   Reply With Quote
Old 01-06-2006, 01:42 AM   #472
M7H
M7H's Avatar
Tell me when this happens, I will stand next to the garbage bin then........
Can anybody place a picture of the broken shaft?
Serpent
M7H is offline   Reply With Quote
Old 01-06-2006, 08:42 AM   #473
Slide, sorry about your frustation. If you are located in America, please send the shaft to Serpent USA and we will replace with a new one free of charge. If you are located somewhere else, contact your distributor.
As a general information, The first batch of the 960 came with a double slotted shaft. Because of the doubble slot, there was not enough material and a few shaft broken. This has being solved. The latest shafts have only one side with slots.
Paolo Morganti
Serpent USA
Paolo M is offline   Reply With Quote
Old 01-06-2006, 08:49 AM   #474
Doug Darby
Hey Doug,
Pegaso......Awesome track!!! Wauu, i just realize that last time i was there was 10 years a go
Anway, setup wise, i think should not be difficult. Start with std downstops, toe, camber, etc. Red springs all around and 40WT oil. Track is (or at least was) very smooth.
Engine wise........you need a lot of Nitro in the fuel, and a very good clutch.
Let me check today and i will send you some suggestions.......
Paolo
Old 01-06-2006, 08:57 AM   #475
Freelander7
Guest
Posts: n/a
Smile
Thank you, so the further away the holes are from the pivot point of the steering shaft the more generall steering you get? What about the distance between the left and right hole on the servo savers? What effect does this have on the car?
When i was at the serpent nations cup in spain in november i noticed one of my teammates shafts broke in half also, serpent replaced it free of charge though which we thought was very good of them
Also does anyone have any idea how much this neew serpent battery pack weighs? http://www.eliterc.co.uk/view_produc...product=903188.
Old 01-06-2006, 09:16 AM   #476
I have a similar pack on my 960 (a Sanyo 900mAh). It weighs 70 grams.
Rob
going4#1 is offline   Reply With Quote
Old 01-06-2006, 11:18 AM   #477
Paolo and Chris..
Thanks for the information, I do have Paolo's Ft. Myers setup and will start out as you advise. Any other information you can come across would be great. A little more exact description of what you mean by "a very good clutch" would be helpful too.
Thanks again for the rapid response.
Doug
Old 01-06-2006, 01:58 PM   #478
C Verano's Avatar
Paolo and Chris..
Doug
Doug,
I think Paolo is reffereing to a clutch setting that is on the aggresive side,strong snap out of the corners.
Chris
Old 01-06-2006, 02:00 PM   #479
C Verano's Avatar
Default vegas?
Lou,
Are you and Glenn going to Vegas?
Chris
Old 01-06-2006, 08:34 PM   #480
Sorry Paolo I live outside the country but I appreciate the guys (like yourself) to address the problem and a fix for it. What got me so angry was that when the shaft broke it took the bearing and the 18T (metal gear) away and I don't even bother to look for it. Honestly I don't mind to buy a replacement shaft but after 15 seasons of racing it is a bit embrassing when u see yr mid belt coming off on the straightway. But I want to say the car is on par and just as good as other brands ( I know becuase I currently own them) and I personally think it is one of the best serpent since vector and more races will be won by this car, that's for sure. Thank you.
Paolo Morganti
Serpent USA
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
