Old 01-13-2009, 07:58 AM   #3211
dj apolaro's Avatar
My set up for Ft Myers is on the serpent.com site. It worked really well this weekend on the very high bite track.
Regards,
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 01-17-2009, 05:28 PM   #3212
Hi...
been a mugen mrx4x for the past year...fed up with stripped belts and transmission not free !!!..... just got a 2nd hand serpent 960 08 spec.
Confused about the the front upright... 1 and 2 are written on the front upright ( are they the wos)...1 on left and 2 on right...is that correct ?
From previous article...more steering does that means swap them over inverted so 2 on left and vice versa.
What about the eccentic, do i need to swap them as well...what they do ?
OS2 conversion in the post
soz for many questions...oh just pre order 966 for this season nationals !!
xtreme888 is offline   Reply With Quote
Old 01-17-2009, 05:37 PM   #3213
dj apolaro's Avatar
Yes,
1 is left and 2 is right
Serpent.com has a manuel if you need. Just go under products, gas, 1/8 scale and downloads.
I do not use the eccentrics. I use the larger bearing on the front instead.
Hope this helps.
DJ Apolaro
Old 01-17-2009, 05:49 PM   #3214
just waiting for uk to stop raining so i can play !!
Old 01-17-2009, 07:02 PM   #3215
captian's Avatar
Originally Posted by xtreme888 View Post
good luck !!!!!!
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 01-18-2009, 04:47 PM   #3216
M7H
M7H's Avatar
Hi...
You don't have to give an excuse for switching.
Mugen might be cheaper on the parts, but in the end, a Snake is hard to beat on durability.....
Serpent
M7H is offline   Reply With Quote
Old 02-02-2009, 01:47 AM   #3217
Default Front Belt Touching
Hi Guys,
Just finished the 960-08. The front belt is touching (just) the steering post (ackerman). Is it just mine or is there a trick there? I can move the rear pulley a bit...
RGDs
Jean
Jeanv is offline   Reply With Quote
Old 02-02-2009, 02:19 AM   #3218
M7H
M7H's Avatar
you should be able to move the small 16T pulley a bit, so the belt runs free...
http://www.mijnalbum.nl/GroteFoto-FKNZSMIB.jpg
Serpent
Old 02-03-2009, 07:30 AM   #3219
Moved the pulley. The belt is away from the tower, but it looks as if the lip on the pulley might wear the belt's side?
Old 02-03-2009, 07:53 AM   #3220
M7H
M7H's Avatar
the lip should have a straight and a chamfered side, the chamfered side should face the belt....
I hope you understand....
Serpent
Old 02-15-2009, 11:39 PM   #3221
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
congratulation to Team serpent at winternats race.....
Give the best while u can !
kschu is offline   Reply With Quote
Old 02-17-2009, 12:04 PM   #3222
Rich Panganiban's Avatar
Trader Rating: 72 (100%+)
Sorry for the SPAM.
Looking to buy any NIP Serpent 950 Parts. Let me know what you have. Thanks, Rich. [email protected]
Rich Panganiban is offline   Reply With Quote
Old 02-26-2009, 04:58 PM   #3223
Default Clutch Problem
For the first time ive fitted the newer flyweights ( the ones with a hole in for a grub screw) No grub screws fitted and flyweights mounted to the pivot pins Alsothe larger thrust plate and a red clutch shoe. The spring is a standard serpent silver and set to 1.4mm on the clutch nut. Clutch gap set to 0.7 with .1 end float.
Within a couple of minutes running the clutch shoe was turning to dust with much heat. Not only this the thrust plate was distorting and as the clutch shoe was wearing down so quickly the clutch bell was hitting and wearing a groove into the thrust plate ?. I stripped the clutch down and replaced again with new parts not changing anything on the settings and once again the same thing happened, what am I doing wrong ?
eigthracer is offline   Reply With Quote
Old 02-26-2009, 05:18 PM   #3224
Winner's Circle's Avatar
When this happened to me I found that my clutch bell was distorted. This happened when it tried to throw out one of the centrifugal shoes. Once I replaced the clutch bell the problem went totally away.
Lee
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 02-26-2009, 05:52 PM   #3225
Greg M's Avatar
Are the flyweights around the right way, as they are opposite to the standard ones. I may have this the wrong way round, but standard flyweights are leading and the ones with a hole in each end are trailing. I couldn't see what difference it made, but changing them to be the correct way around, I wasn't going through a shoe every tank or 2. The clutch bell needed a sand after that to smooth it out and so far no problems now.
Greg M is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
