Old 09-20-2008, 09:50 PM   #3121
Suspended
no matter what they say that serpent is going downhill from what i read....i feel that serpent is a good car(s)....
OILMAN is offline   Reply With Quote
Old 09-21-2008, 09:37 PM   #3122
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
serpent definately a good car.....
Give the best while u can !
kschu is offline   Reply With Quote
Old 09-21-2008, 11:07 PM   #3123
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Hehe.. good for you Chu.. you just out raced everyone at the track yesterday. Congrats... until... the PB give way... too bad
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 09-22-2008, 06:45 PM   #3124
kschu's Avatar
i'm just lucky in d qualifying and unlucky for d final ....
Old 09-23-2008, 12:30 AM   #3125
kschu's Avatar
guys, please give me some comment on my driving...
heat 1
http://www.youtube.com/watch?v=pMCctX4ntY0
heat 2
http://www.youtube.com/watch?v=0sAUsvy8sNc
Old 09-23-2008, 01:59 AM   #3126
kschu's Avatar
guys, i would like to ask what d effect if i use hole 1 or hole 2 ??
the 2nd picture is for wat ??
Old 09-23-2008, 05:20 AM   #3127
Pattojnr's Avatar
Trader Rating: 19 (100%+)
this can raise or lower your body mount position. this with the top of the mount positions raise or lower the body. so if you require a little steering, lower the mount by using the lower hole. if you need a little more rear grip, then raise it. obviously the lower positions have the most effect. the top positions are a finer adjustment.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-25-2008, 12:26 AM   #3128
kschu's Avatar
how come so quiet here?
any1 using serpent pro starter box?
Old 09-25-2008, 12:39 AM   #3129
jfc_tech's Avatar
I have. whats the problem?
Old 09-30-2008, 08:13 AM   #3130
Default Problem adjusting wheelbase to -4mm
Hi. I was trying to reduce the wheelbase by 4mm in my 960 but ran into a problem. The rollbar mounts wont come back enough for me to put the 4mm spacer in front of them.
Is anyone running -4mm wheelbase and how did you solve this problem ?
Storm_PT is offline   Reply With Quote
Old 09-30-2008, 10:15 AM   #3131
gearhead_22's Avatar
Send a message via AIM to gearhead_22
In order to shorten the wheelbase you have to take the 4mm spacers from behind the upper and lower arm and put them in the front you also have to and a 4mm spacer between the front lower arm and the swaybar mounts. hope this helps.
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 09-30-2008, 12:41 PM   #3132
Ok, so i have to put a 4mm spacer in the screw that connects the lower arm and the rollbar mounts ? Is that the same type of spacer used for caster/wheelbase adjustment ?
Old 09-30-2008, 12:48 PM   #3133
you got it
Juwan Hunter
Old 10-03-2008, 10:53 AM   #3134
kschu's Avatar
do -4mm wheelbase give big difference in car responsive or in stability ? i did try using -3mm wheelbase but i dont feel any different with it.
now i using -2mm wheel base with 4mm caster which i feel d car much smoother in corners and also sweeper.
Old 10-03-2008, 11:16 AM   #3135
Well, acording to the Serpent setup booklet:
EFFECTS OF WHEELBASE ADJUSTMENT
Longer Wheelbase
• Car more difficult to turn around sharp corners
• Increases stability
• Better handling over bumps and ruts
• Better on more open tracks with high-speed corners
Shorter Wheelbase
• Car turns sharp corners more easily
• Increases steering response
• Better on tighter, more technical tracks
• Increased rear traction under acceleration
... so -2mm should feel smoother than -3mm. My track has a very technical infield that needs the car to turn quickly thats why i wanted to try -4mm.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
