Old 09-09-2008, 01:33 PM   #3091
Originally Posted by fly_wheel View Post
the track is in sabah, malaysia...
Ron (Duneland): I don't think you'll be adding that track to the Midwest Series
Walt is offline   Reply With Quote
Old 09-09-2008, 06:39 PM   #3092
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by duneland View Post
I watched your video, and you were getting around quite well for your first run. However, I didn't see any signs of excess traction. Actually, it looked a bit loose. You had one flip near the end, that was induced by contact with the curb/berm. It looked as though your pit man is responsible for marshalling your car! Bummer, you lost a lot of time on those two crashes..
Keep it up!
Where is the track btw?
the place tat i flip is because d traction is high causing my rear stick there and cause me hit d curb....for me some place still not enough steering....actually i like to drive understeer for my ep as i can use last minute brake but since brake is not allowed in driving 1/8 so i guess i need to make d car more steering yet not oversteering...now the car is understeer in certain corner where i cant take tight corner....
i heard we need to truer the rear tyre to certain size to get the best performance out from the tyre when race qualifying. Wat size is recommended ?
normally how low or high d spoiler should i put? i'm using central shell..
d picture is d 960 i'm using now...
Give the best while u can !
kschu is offline   Reply With Quote
Old 09-14-2008, 06:58 PM   #3093
kschu's Avatar
guys ,i has a serious problem here.. i broke 2 Spring steel CVD. its didnt break because of accident or hitting somethng hard but it's break smoothly... both time break after i finish run the sweeper and suddenly feel d front got problem. i go down and check , found out that the cvd is broke.. i dont see anything binding there..
please advice...
Old 09-14-2008, 10:03 PM   #3094
kschu's Avatar
any1 know how to see this thing ??
Old 09-15-2008, 12:05 AM   #3095
fly_wheel's Avatar
please advice...
u r getting too fast in too short time...
fly_wheel is offline   Reply With Quote
Old 09-15-2008, 12:18 AM   #3096
kschu's Avatar
i wish i'm faster......
Old 09-15-2008, 05:55 AM   #3097
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
First you got to choose what is your problem: oversteer or understeer. Then the location of the problem, corner entry, corner exit, mid corner. Afterwards, pick if its on-throttle or off-throttle. Then after picking these three, you have selected only 1 row... Within 1 row you will find what changes you need to make in order to eliminate your problem. If its green, means it needs to be soften, lowered or somewhere along that line. If its red the opposite. The numbers are there to tell you which has the biggest effect on your problem. 1 being the highest.
Hope this helps...
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 09-15-2008, 07:01 AM   #3098
Doug M's Avatar
Default Paolo Morganti and Serpent 960 win!
Congratulations to Paolo Morganti! Paolo, driving his Serpent 960, was the winner of the A Main at the season opening FORGASS Series Race held at Homestead RC Raceway over the September 13, 14, weekend.
Doug M is offline   Reply With Quote
Old 09-15-2008, 04:03 PM   #3099
captian's Avatar
congrats to you paolo on your win serpent all the way baby
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 09-16-2008, 12:49 AM   #3100
new3's Avatar
Originally Posted by Paolo M View Post
Congrats DJ on the Podium finish at the GLC. Way to go!!
con grad if it is possible can you post your latest setup for os2 thank you
www.new3racing.com, OFNA, Mugan MRX5wc, www.speedshophobbies.com, western engineering, redline racing fuels,
new3 is offline   Reply With Quote
Old 09-16-2008, 10:50 AM   #3101
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Keep it up!
HMS Racing Speedway Kolombong Inanam Sabah Malaysia.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 09-16-2008, 01:46 PM   #3102
duneland's Avatar
please advice...
My best guess would be a combination of running a narow front track (with bone going deep into the outdrive) and too much suspension travel. This could result in contact between the outer edge of the outdrive and the shaft where it broke. I have never seen one snap like yours. I have bent a few, but never broke.
duneland is offline   Reply With Quote
Old 09-16-2008, 06:49 PM   #3103
kschu's Avatar
the outdrive has a 1mm shim before put into the one way.. i think it's a default rite?
another thing is, i notice the both broken CVD(left) is short around 1-2mm than d right CVD. will this causing the problem ?
my front droop is -1 , camber is -1, ride height is 7mm.
Old 09-17-2008, 12:39 AM   #3104
RockyMania's Avatar
Trader Rating: 17 (100%+)
Hi guys...
Im new in this threat as ive only just went into 1/8 GP recently. Driving serpent 960 07. Simple question, i am using a front dogbone axle. I noticed the front dogbone being a lil too short when turning my steering full, ie. possible of dogbone flying off! I thought of reducing the front width so that my dogbone goes deeper into the outdrives n therefore reducing the possiblity of the dogbone flying off as i turn my steering deep. However, by doing so, the front tires will seem to have contact with my knuckles....any advise besides changing to CVD? thanks
RockyMania is offline   Reply With Quote
Old 09-17-2008, 01:46 AM   #3105
jfc_tech's Avatar
response from the Pro will only come in the early morning.
So sad, one broken (kschu), one worry that its going to break (rocky). Why don't you guys ask Ah Boon or Chris. I'm sure they know this. Other than new kit or new parts.
I suspect you two drove too fast for others to duplicate the same problem. Hehehehe. Just kidding friends.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
