Old 09-06-2008, 02:44 AM   #3076
hey
just after a part number for the engine mount for the 960 08 so i can mount my RB as the holes in the mount are to close together
rcmad2700 is offline   Reply With Quote
Old 09-06-2008, 02:49 AM   #3077
Greg M's Avatar
I think there is only one, plus I've got an RB in mine with the standard mount?
Greg M is offline   Reply With Quote
Old 09-06-2008, 06:15 PM   #3078
yer just looked at the measurments on the RB web site and the speedline XA is the same as the C6 so i dont know what is going wrong with the mount
Old 09-06-2008, 06:18 PM   #3079
oh i didnt see that you are running a C5 but i think they are the same
(i hope)
Old 09-07-2008, 06:41 PM   #3080
just really need to knoe what engine mount will fit the RB Xenon ALPHA as the standared one aint gonna work.
Old 09-07-2008, 07:26 PM   #3081
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
hi guys, i'm new to 1/8th scale as im playing 1/10 s400 before... im using 960 with 08 conversion...
my question now is , wat should i do if i encounter traction roll ?? wat setting should i need to apply on d car?? the track is very grip as the race organise will spray sugar treatment on the track before the race start.
thanks
Give the best while u can !
kschu is offline   Reply With Quote
Old 09-07-2008, 08:44 PM   #3082
soc123_au's Avatar
R/C Tech Charter Subscriber
The mono block mounts the Alpha with no problems. I pulled my C6 out & bolted the alpha straight in.
For all those having meshing issues, stick a .5 shim behind the flywheel cone, meshes perfectly & you can still get heaps of adjustment in clutch gap. I have done this & run .9 gap & still use shims.
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Old 09-07-2008, 08:47 PM   #3083
mmmm well mine and my bros havnt been macheened properly as the mouning hols dont line up even. i have the front 2 screws in and the rear is out looking fromt the exhust side off the engine the left is .5 mm out and the right is like 1.5mm out
Old 09-07-2008, 08:48 PM   #3084
soc123_au's Avatar
Originally Posted by Pattojnr View Post
i have a lipo on the way to lower the tank a little, so i should get rid of my carb issue. thanks.
You need to turn the carb to change the angle & then adjust the ball at the end of the slide. Its a bit fiddly to get right but you can run the car with a standard 5 cell flat pack. Lipos are a better option though & the AAA packs have a tendency to come apart with the vibrations.
Auswide Hobbies
JPM Racing
Old 09-07-2008, 08:53 PM   #3085
soc123_au's Avatar
Sounds like you may have a bad engine mount, if you contact your local Serpent importer I am sure they will sort it for you.
Just something else to try first, have you tried mounting the engine into the mount off the chassis? I have ground my mount down to give more clearance for adjusting mesh etc. It is possible your engine is twisting slightly because of the tight clearances.
Auswide Hobbies
JPM Racing
Old 09-08-2008, 05:16 AM   #3086
Pattojnr's Avatar
Trader Rating: 19 (100%+)
just finished up the paint. , here it is
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-08-2008, 09:31 AM   #3087
duneland's Avatar
thanks
There are many things you can do to keep the car off it's lid. You are lucky that the problem is excessive grip rather than the reverse!
Here are a number of things you can do;
Small tires... Lowest ride height track surface will allow... Stiffer springs... Harder compound tires... Change roll centers (raise the inboard lower hinge pins to the highest location and shim the upper-front arm mounts upward)... Stiffer sway bar settings... Make sure the body is mounted as low as possible without significant tire contact... Reduce the number of holes in shock pistons, ie. if you have 4 hole pistons, go to 2 or 1...
duneland is offline   Reply With Quote
Old 09-08-2008, 06:31 PM   #3088
kschu's Avatar
ok, i will try it up...thanks for your advise...
below is my 1st race with 1/8th
http://www.youtube.com/watch?v=ypnAl8tOO38
Old 09-09-2008, 09:38 AM   #3089
duneland's Avatar
I watched your video, and you were getting around quite well for your first run. However, I didn't see any signs of excess traction. Actually, it looked a bit loose. You had one flip near the end, that was induced by contact with the curb/berm. It looked as though your pit man is responsible for marshalling your car! Bummer, you lost a lot of time on those two crashes..
Keep it up!
Where is the track btw?
Old 09-09-2008, 01:11 PM   #3090
fly_wheel's Avatar
the track is in sabah, malaysia...
fly_wheel is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
