Serpent 960....
#3046
hey
just tried to fit some old rims from my 950R and first 960 on my 960 08 and they dont fit on the rear, its like the axle is to short for the rim. just wondering if the axle from my 950R will swap ova or is there some thing wrong with the kit. will i have to use mug or kyo wheels.
thanks
thanks
#3047
hey
thanks
thanks
#3050
im building my 960 08. there are 2 plastic inserts in the rear axle.
im still building , but im guessing the inserts are too long. there is a long and short, so im guessing something to do with the OS2 and std axles. but with the short inserts, the dog bones bind up and prevent any further suspension travel. i have set the pivot balls as per the instructions, so i havent checked track width yet. but i will get there, if anyone has built the 08 kit, and have got past this problem, please post as im trying to get it all together to run it this sunday. so all help would be apreciated. thanks.
#3052
I am running the OS2 version and I did not use any inserts in the rear. When you build it just make sure that the dog bones can not come out. They will have slop (side to side), but that is fine.
DJ Apolaro
DJ Apolaro
#3053
i think the manual has issues, if you build the top arm length to the manual, then they say to use the long arm for the inserts. this gives the car too much rear camber, and this is binding up th esuspension due the dog bones binding. so i changed the insert to short top arm and it seems better. i also have issues with clearance with the rear shocks. if you use the most layed down position, the hinge pins and the carbon for the body mount interfere with the shock collars. so i have used the middle hole for the shock position at the rear.
#3054
To lay down the shock I use 3mm washer on the top part and a 1mm washer on the bottom part were you screw in the shocks. It will be fine. I have had NO problems.
DJ Apolaro
DJ Apolaro
#3056
When i lost the insert in one of those close encounters with the wall, i used a small fuel tube instead. It serves the same purpose, can be cut to size and even if too big wont make the dogbone bind.
#3057
Thanks guys. The car was really awesome. By the end of the weekend I had my car working really well. My set up is quit different than I think most others. By the time I was done I had this.
front
1 hole piston with 35wt oil and new green springs upper position on new tower
rear
2 hole piston with 40wt oil and new blue springs and lower position on tower
front
rear
Whenever 'shock oil' is quoted on this thread, is it safe to assume that this refers to 'Serpent brand' shock oil?
It seems that Serpent 'wt' is way different than some of the others that use 'wt' (like Associated and Losi), so I think this is an important distinction to make. I've heard from reliable sources that a Serpent 40wt is thicker than an Associated/Losi/Trinity 80-90wt.
Follow up question: anyone know where I can find Serpent brand shock oil, preferably in the US? It looks like Serpent part number 1679 is a shock oil assortment that I'd like to get to be able to copy setups posted here as well as on the Serpent web site, but I have not been able to find it yet anywhere.
Thanks.
#3058
http://www.kamikazetoysandhobbies.com/home.htm
Give this guys a call. I coulnt find the oil on the website, but give them a call and they will get it for you.
#3059
DJ (and others):
Thanks.
Thanks.
DJ Apolaro
