Old 08-06-2008, 02:16 PM   #3031
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
Originally Posted by UPSguy View Post
Why would one not use the sway bar?
Removing the sway bar in the front will allow for a decrease in steering response and an increase in roll which can equate to more steering mid corner and corner exit.
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 08-06-2008, 03:13 PM   #3032
Thanks for the answer.
The man on top of the mountain didn't fall there.
UPSguy is offline   Reply With Quote
Old 08-06-2008, 03:17 PM   #3033
dj apolaro's Avatar
Nice
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 08-08-2008, 04:27 PM   #3034
Default Rear roll bar position
Hi Guys,
I can't seem to use the rear lower arm centre hole position for my anti roll bar... the rear lower arm seems to be blocking the ball-end.. and when i use the new position on the arm (outermost hole), I have to chamfer the ball ends slightly in order not to allow the ball-end to be binding with the arm.. Pls advice
backplate is offline   Reply With Quote
Old 08-08-2008, 04:46 PM   #3035
Are you mounting the swaybar links in front or behind the arm?
Old 08-09-2008, 10:47 AM   #3036
I'm mounting it on the spur gear side... which means i have to tighten the ball using my 3mm allen key from the spur gear side..
Old 08-09-2008, 10:54 AM   #3037
Does this happen on both arms, left and right, or just one? Did you try flipping them too? All the cars i've built have had no problem with swaybar mounting positions on the arm. Maybe you can take a picture, to help illustrate your problem.
Old 08-09-2008, 10:57 AM   #3038
I've tried flipping them over, it got worst.. currently i'm using the hardest hole, after some chamfering the ball joints it fits, i suspect mine could be the old 960-07 arms.. because i have some parts problem when i got this kit..
Old 08-09-2008, 02:53 PM   #3039
duneland's Avatar
Spur gear side? Does this mean you are mounting the link with the screw through the mounting tab, from rear to front, leaving the link (with ball and ball end) on the front side of the mounting tab? If so, that is wrong. The screw goes in from the front, the sway bar link mounts on the rear of the mounting tab. When using the outermost position, you can't get a completely straight shot at it. The shock mount is a bit in the way. I have to use a ball driver because of the slight angle. No champfering of any parts required.
duneland is offline   Reply With Quote
Old 08-09-2008, 04:23 PM   #3040
If he did mount it that way, its not his fault. The new Revision of the 960'08 manual instructs owners to install it this way.
But once again, going back to all the previous 960's that have passed through my hands, either way has no problems. I'm boggled. I really want to see a picture..
Btw, 960'07 - 960'08, rear lower arms, the only change made was the pivot ball placement, in that they became closer together.
Old 08-10-2008, 02:12 PM   #3041
duneland's Avatar
Now that I look at mine, with the new OS2 arms, it looks like it would be better the other way around. Can't imagine what's wrong with his.
Old 08-19-2008, 08:19 PM   #3042
hello
just finished my 960 08 kit and i have a copple off questions.
wil the Wheel-axles front is it the WOS one or normal, because there is a 4 small shims and one large and a coned one for both left and right. so were excactly do these shims go all on the out side ff the hub or on the inside iam a little confused.
and also is there ment to be a setup book with the kit.
and is it the one off the net or is there an updated one for the 960 08
thanks Dan
rcmad2700 is offline   Reply With Quote
Old 08-19-2008, 08:46 PM   #3043
Greg M's Avatar
Originally Posted by rcmad2700 View Post
hello
thanks Dan
I also didn't get a set up book with my kit.
As for the shims, I put all on the outside, but I still have some slop, so bought some more shims to remove the slop.
Greg M is offline   Reply With Quote
Old 08-19-2008, 10:50 PM   #3044
thanks man
iam thinking off putting on the Shim wheel axle conical off my 950R, but not shour if they will work.
cant wait to run it, its been 3 years since ive run a 1:8 onroad.
Old 08-20-2008, 12:22 AM   #3045
soc123_au's Avatar
R/C Tech Charter Subscriber
The conical shim from your 950R will swap straight over. I think they should make that part standard as it makes everything fit much nicer.
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
