Old 01-29-2008, 07:15 PM   #2701
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
the part #'s are on the serpent site as for the parts give serpent usa a call in florida and they will tell if there available
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 01-29-2008, 07:21 PM   #2702
Team Kamikaze's Avatar
Originally Posted by sepentNY View Post
Hey guys, I have a question I have a serpent 960 07 and I want to turn it to a 08 960 what parts do I need, to do the convention ( specify # parts please) thank you. And where I could find a chip parts? thanks..
There will be a conversion kit that comes with all the necessary parts to convert your 07' to an 08' including the chassis, I will post here once I got those in.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 01-29-2008, 09:14 PM   #2703
occ
Trader Rating: 15 (100%+)
Questions??
With the aluminum front upper suspension brackets, how do you lock in the pins? Do you just tighten the crub screws onto the inserts which then lock them in?
The pin has a flat spot but it does not get used. Is this correct?
occ is offline   Reply With Quote
Old 01-29-2008, 09:47 PM   #2704
That's it. Tighten the grub screw to lock them in. The pin does have a flat spot. What do you mean when you say 'does not get used'? I've never had a pin pop out on my 960 so I'd guess mine is getting used. Anyone else?
going4#1 is offline   Reply With Quote
Old 01-29-2008, 09:58 PM   #2705
As others have mentioned, conversion kit is coming. It will include new plastics on top of the already mentioned chassis. I wonder if it will include the single piece engine mount and centre alu bracket. I guess it would if it's a 100 percent conversion. If you've got those parts already then you'll . . . . have spares! Hello Ebay!
Given what's changed, the full upgrade won't be cheap. Complete guess here but I'd say somewhere around $250. For those with upgraded 960s already, the full upgrade won't make sense. That's why there are smaller upgrades (e.g. OS1 and OS2).
Does anyone know if there will be more than 3 upgrade kits (i.e. OS1, OS2, Mega-Ultra-Full Blown)?
Old 01-29-2008, 10:29 PM   #2706
occ
Thanks for your reply.
It seems the flat spot on the pin only gets used with the plastic brackets. It doesn't line up with grub screw on the aluminum brackets.
Or, do you use grub screw in the arm to lock the pin instead of the brackets?
I hope I'm not confusing you all because I'm starting to confuse myself!
Old 01-29-2008, 10:50 PM   #2707
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
Just tighten the setscrew, i know exactly what youre talking about. just make sure the flat spot faces where the setscrew sits, but it does actually get used. When the plastic insert sits inside the alum upper arm bracket, the now "deformed" plastic will fill the void of the flat spot machined on the hinge pin, which will prevent movement of the hinge pin and thus, never losing them.
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 01-29-2008, 10:54 PM   #2708
occ
Thats great, I'm glad you understand what I mean. I will do as you say.
Thanks for your response.
Old 01-30-2008, 02:14 AM   #2709
M7H
M7H's Avatar
Originally Posted by border r/c View Post
yep landed here from the first batch
ready for the Winternats
my new combo for season 2008
Serpent 960-08- F180 Sirio-XCEED-Tires
ps: next batch will be in 1/2 Feb.
Michel, very nice body!!!.....
Can you arrange a few for me?.....
M7H is offline   Reply With Quote
Old 01-30-2008, 08:26 AM   #2710
Pyramid's Avatar
Buy from LHS is your best bet,
Conversion Serpent 960 07 to Serpent 960-08 OS1 front and rear
- The following parts are needed:
o 903252 Upgrade-set 960 to v08 OS1
Conversion Serpent 960 07 to Serpent 960-08 OS2
o 903266 Wheel-axles FR OS2 (2)
o 903267 Lever alu/spring/pin OS2 FR (2)
o 903257 Upright OS2 (2)
o 903268 Wheel-axles RR OS2 (2)
o 903269 Lever alu/spring/pin OS2 RR (2)
o 903235 Shim 12x15x0.25 (10)
Conversion Serpent 960-08 from OS1 to OS2
- For the front the following parts are needed:
- For the rear the following parts are needed
o 903254 Upgrade set OS2 rear
Pyramid is offline   Reply With Quote
Old 01-30-2008, 01:27 PM   #2711
Most of those part #s aren't on the Serpent website yet?
The man on top of the mountain didn't fall there.
UPSguy is offline   Reply With Quote
Old 01-30-2008, 01:57 PM   #2712
Another question as the Serpent website is confusing. When you look at the list of optional parts for the 08 the WOS steering blocks are listed as an option. When you look at the PDF files of the build manual and reference manual they are listed as standard. Which is correct? Secondly I realize these are tuning options compared to the original steering block, is one of the setting of the new block the same as the old block?
Old 01-30-2008, 02:07 PM   #2713
Sorry for all the questions but I am new to this. Why would one want to use the laydown throtle servo and add another linkage to the works? The standup servo setup is simplier?
Old 01-30-2008, 02:37 PM   #2714
captian's Avatar
the lay down is for better CG
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 01-30-2008, 02:53 PM   #2715
captian's Avatar
paulie b when you getting your i see you lookin
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
