Old 09-30-2005, 08:44 AM   #241
sn4il's Avatar
I use a standard 1400mah 5 cell flat pack in mine.
Is 1400mAh the biggest capacity You can get in that size??
max
sn4il is offline   Reply With Quote
Old 09-30-2005, 09:09 AM   #242
Default Batteries
I just picked up two SMC 1200 mah packs and an additional battery tray. The method I used to install the batteries on the tray was to... 1.) Cut the manufactures shrink wrap off (as Aaron pointed out ealier).. 2.) Then I actually sanded the battery trays just slightly on the left and right side. 3.) I then took the two pieces of about 1/2 inch shink wrap and "banded" the front and back of the battery on to the battery holder or you can use tape. 4.) After this "normal" step, I went ahead and shrink wrapped the whole tray and battery.
The "light" sanding on each side of the battery tray allowed the additional shrink wrap to still fit into the chassis and create the naturally snug fit, but in this way, I can ensure two points I was aiming for.. I keep fuel and dirt away from the battery and it's connections, and the second point is to reinforce the battery so during hard hits or flips the two bands alone at each end aren't the only holding force on the battery potentially putting a strain on the connection joints (solder tabs or spot weld connections).
Well see if it actually works :-0
Darint is offline   Reply With Quote
Old 09-30-2005, 09:17 AM   #243
C Verano's Avatar
max
I think that is the largest capacity.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 09-30-2005, 09:53 AM   #244
Trader Rating: 16 (100%+)
Originally Posted by aaron_buran
The lower front a-arms are the same, the upper front a-arms are a bit longer due to the deeper offset of the pillow ball in the steering block, but you can still use your old ones up, there just not as strong as the new ones.
Aaron....I heard you are heading to Hamilton this weekend, if that is the case, please let me (us) know about their new track surface, I heard they reseal their track and previous setup might not work....
Does 35s still good with red springs or need to step up (hard) to 37s and blue like you mentioned on mytsn...thanks (Howard)
Old 09-30-2005, 10:16 AM   #245
duneland's Avatar
The size of the rx packs you guys are referring to is 2/3 A. 2/3 C would not fit in any 1/8 car. Just trying to reduce any possible confusion.
I have 1200 mah LiPos that fit in the 950R, XR8 & 960 in stock. Will bring some with to Cinci.
duneland is offline   Reply With Quote
Old 09-30-2005, 10:30 AM   #246
Buyer Beware
does anyone sell this pack already made?so i can fit it right in?my boyfriend is almost done with the 960...
HELLOkitty is offline   Reply With Quote
Old 09-30-2005, 10:41 AM   #247
Ron....I would like to see those, I have the 950R, 835 and some 705....those AAA just drive me nuts...
Old 10-01-2005, 01:26 AM   #248
ghoppa's Avatar
Trader Rating: 54 (98%+)
Is it just me, but why does the front belt "just" bearly touches the servo saver????? (is it enough to bother???) I tried various positions for the inside pulley, but you can only go so far (left or right) without hitting the mid bearing block either way????
other than that, my front end is done, and I forgot how nice "Serpent's" in general go together.....(Nice Hudy Spring Steel)
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 10-01-2005, 06:46 PM   #249
even 950-R had that problem. just make sure the bearing on the mid block is pushed all the way in. and you should be able to slide 16t pulley over a bit more. when it's done correctly you should see a gap of about a 1mm between the belt and the servo saver.
scottbaek is offline   Reply With Quote
Old 10-02-2005, 10:46 AM   #250
Pyramid's Avatar
Yes, grind the ssaver a little to make more room for belt's play.
Pyramid is offline   Reply With Quote
Old 10-02-2005, 03:20 PM   #251
sn4il's Avatar
I'm trying to use Hudy All-in-one aligment tools with 960. I cant figure out how to setup track width without tires to get proper measurments.
Is anyone using this Hudy setup and can give me an idea?
mAx
Old 10-03-2005, 02:48 PM   #252
Winner's Circle's Avatar
Default Li-poly battery results
I tried the 1320 mah li-poly pack out this Weekend and everything went great. No problems at all. The batteries are in a Serpent 960 and they fit beautifully. They weigh about what the 700 mah Serpent pack does but have 2x the capacity. Hopefully this marks the end of the batteries dying while on the track racing.
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 10-03-2005, 02:53 PM   #253
Buyer Beware
where can i get this batt pack for the 960?
Old 10-03-2005, 06:25 PM   #254
ghoppa's Avatar
Question: Why don't you guys just use the 5 cell (2/3 size) 1400 mAH receiver packs Ni-Mh that are available???? They fit right in there perfectly?????? is there that much of a weight difference????
Also, have you weighed your cars yet??? (race trim???)
Old 10-03-2005, 06:27 PM   #255
whynot's Avatar
Trader Rating: 18 (100%+)
Ghoppa. I agree I have them in my car and they work great and the car handles great.
whynot is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
