Old 07-16-2007, 01:40 PM   #2401
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
Originally Posted by gearhead_22 View Post
I am putting together a serpent 07 960. I am having a problem with the servo arm hiting the chassis. I am using a jr 9000s with the rubber ends. It looks like the rubber ends are pushing the servo out too far.
Steering or throttle?
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 07-16-2007, 01:55 PM   #2402
gearhead_22's Avatar
Send a message via AIM to gearhead_22
steering (sorry)
gearhead_22 is offline   Reply With Quote
Old 07-16-2007, 03:08 PM   #2403
GHETTOTEACHER's Avatar
Check that you put the right spacers for your servo. I have rubber gromitts for my airtronics. Check your spacers.
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
Old 07-16-2007, 04:37 PM   #2404
I am not using any spacers.
Old 07-16-2007, 04:47 PM   #2405
The servo horn is hitting the chassis? As in the height of the servo mount is wrong or what?
Old 07-16-2007, 08:08 PM   #2406
The servo horn is not in the gap of the chassie when I turn . It catches the lip.
Old 07-16-2007, 08:21 PM   #2407
You are gonna have to mill in a knotch on the chassis plate. I'm running a aluminum horn and I did that. It works fine.
Is this what you are talking about?
Old 07-16-2007, 08:24 PM   #2408
Mine just barely touched with a 9000s, in the same location as the picture from "Ghettoteacher". I just took a dremel sanding wheel and notched the underside of the graphite plate enough to clear the servo arm.
Darint is offline   Reply With Quote
Old 07-16-2007, 08:50 PM   #2409
here is pics of my problem
Serpent 960....-960-001.jpg   Serpent 960....-960-002.jpg   Serpent 960....-960-003.jpg
Old 07-16-2007, 09:09 PM   #2410
I dont understand, are we talking about the radio tray or the chassis?!
are you currently using a plastic horn or an aluminum one?
Old 07-16-2007, 11:02 PM   #2411
Hey J, I was looking at the pictures and my chassis for about a half an hour. Two things I see. Mind you, my 960 is not a 07 so I don't know about the changes to the kit.
1. Your steering servo bracket is different than mine. I don't have the two holes on the top my bracket.
2. Your servo arm looks different. I know that I replaced the arm with an aluminum one but.... ?????? It should fit.
Old 07-17-2007, 02:15 AM   #2412
The steering servo mount included in the newer kits have an optional transponder mount. (#903197)
The transponder mount itself is carbon fiber (#1666).
This setup is also available as a set. (903196)
As far as the horn goes, it looks like the factory one, but i still dont see where its possible that the horn hits the chassis..
Old 07-17-2007, 05:06 AM   #2413
avs
avs's Avatar
either
the horn has more offset,
the output shaft is offset from the servo body
most likely the servo body is offset from it support bracket
avs is offline   Reply With Quote
Old 07-17-2007, 05:40 AM   #2414
I see the challenge, the JR 9000s is a larger/taller than average servo. The servo mount (with our without the 2 holes for the carbon transponder holder) is the same size.
Using my 9000s, I actually mounted my servo from the inside of the servo mount, which took a touch of grinding on the servo mount to get it to fit. The challenge is when you mount the JR servo with the mounting lugs on the outside of the servo mount instead of the inside of the servo mount the taller JR servo extends to far across the carbon opening.
Old 07-17-2007, 06:10 AM   #2415
Thanks, that is my problem. Hey big H are you racing at 301 this weekend?
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
