Old 07-09-2007, 08:30 PM   #2386
new3's Avatar
Originally Posted by CIMRI View Post
Did you mean less downstop on the rear?
ps: I sent you a pm. sorry fatal error
yes
www.new3racing.com, OFNA, Mugan MRX5wc, www.speedshophobbies.com, western engineering, redline racing fuels,
new3 is offline   Reply With Quote
Old 07-10-2007, 01:17 AM   #2387
CIMRI's Avatar
new3,
thnx for information. I am intresting at your setup. Can you post me your setup?
btw. Thnx all your guys, Nigelnugets, new3, darint, jhonny...etc. for your. I noticed very usefull information and will try this weekend.
CIMRI is offline   Reply With Quote
Old 07-11-2007, 12:57 AM   #2388
new3's Avatar
new3,
ok
front:
shocks: 2 holes 400wt. mugan, Serpent purple
hangers -1 inside hole
track: 253
caster2 mm behind camber 2 degrees
droop 0
ackerman wide long (note if you have to much steering, wide short)
wos steering nuckles 1 left 2 right 1 tow outboth sides
tires 68 mm shore 38
shock tower lower hole
lenth 3 mm short
ride height 7
rear:
shock 2 holes 400wt mugan, serpent purple
rear roll center middle
upper rear arm outside hole
track 265
rear lower arm out for swaybar and they are flat
mount to the out side hole on rear body mount
Body; central lola mount with hole as marked
tires 75mm shore 38
rear droop 9
2 tow in 3 camber
mount to lowest hole on the shot tower
ride hight 8
note if you need more rear traction drop fron 75 to 74.5 this will give you
more traction. if you need more with the rear roll center bulk head in the middle and on the rear plate on the bottom to give anti squat. if this is to much then you have to get the 720 roll center pin and use there middle ones they are ofset so in the bulk head it is high in the back plate low. still working with the car but this is where i am at right now it carries a lot more speed into the corner. and it rotates better, and it recovers incredible. if it is to quick from side to side go to 500 wt mugan or serpent 35 wt. if you want a little more drop rear ride height to 7.5. again this setup is not for everybody, it is very agressive. i have given you some note on how i am control the feel of the car. try things one at a time. and i remind you this setup requires a differ driving style so if you try you will have to getuse to it. dont use a lot of breaks it will spin out the car. you will have to use throddle tocontol the car
Old 07-11-2007, 01:13 AM   #2389
new3's Avatar
new3,
oh yeh i forgot i use for cental rc there transmission conversion cr 504. this help the car off the corner
Old 07-11-2007, 12:46 PM   #2390
CIMRI's Avatar
thnx for reply. your set up is really radical I have a smooth driving style . But I'll try.
Old 07-11-2007, 04:34 PM   #2391
Ffejdat's Avatar
Cimri- I am not sure how the Blitz body you are running compares to others, but I would urge you to try the Central Lola body, that seems to give great steering...
Ffejdat is offline   Reply With Quote
Old 07-11-2007, 09:00 PM   #2392
Registered User
ok
front:
track: 253
droop 0
lenth 3 mm short
ride height 7
rear:
track 265
tires 75mm shore 38
rear droop 9
2 tow in 3 camber
ride hight 8
Hey new3, it looks like you are pretty good in setting up the 960, can you help me set up my 960?
SamSung is offline   Reply With Quote
Old 07-14-2007, 11:17 PM   #2393
new3's Avatar
ok what is the matter with your car.
Old 07-15-2007, 08:49 AM   #2394
Registered User
1st of all I need parts for my 960, where can I buy it? I live in San Bernardino area, by the way are you a Serpent Team Driver?
Old 07-15-2007, 06:04 PM   #2395
Winner's Circle's Avatar
Check www.gasrccar.com/eshop
We have a huge inventory of Serpent parts.
Winner's Circle is offline   Reply With Quote
Old 07-15-2007, 08:21 PM   #2396
new3's Avatar
actually i am not i race out at crystal park, i have been racing for about 20 years i get help from other people for tuning motors. but i do my own setups. i take what the manufacturer and run the car that way for about a month and see howthey want the car to react. if i like it so be it if not you cange one setting at a time to get your car to reacrt as you would like it. you can go to KamikazeRCRacing.com. talk to sam and nigel. idf you come to crystal park raceway walter diaz races down here he is a serpent team driver as is nigel. one of the best things that you can do is bench race. this is how you learn things. in fact i believe bt express is holding the first of a series of races at crystal park and sun valley. most racers are very approachable so bring your car ask questions and learn about your car. kamakaze hobbies is in the area so just call them. ive seen walter and nigel fix peoples cars at the track. i help, glen williams, chris verono, robbie collins, if you catch mike swagger on a practice day and he not to busy he'll help too. he wont fix your car but he could give you advice.most of the racers are very helpful. race days can be very frustrating at times so it isn't the best time to try to get your car fixed. so come on down i'm sure someone will help you. what track do you race at?
Old 07-16-2007, 07:17 AM   #2397
duneland's Avatar
Some info on LiPo rx.; I have been using a THP 1320 in my 960 for about 1 1/2 seasons. It bit the dust recently.. I attribute its demise to the use of a brass battery holder. I recently made the holder to add weight. The brass cunducts heat from the chassis-engine and passes it along to the battery. LiPo is good up to about 140-150 degrees. Track temp at the Byrons race was about 150 degrees. In long races the chassis can get quite hot. This is all a formula for LiPo failure. At the Byrons race, my pack dumped at about the 56 minute mark. When the pack was good, it would go for hours.
I went back to the fiberglass holder and replaced the pack.
I don't know what the brass holders from Serpent look like, but I would recomend thermal insulation between the holder and chassis. I will mill the mounting tabs down a bit on mine & mount with shock o-rings between chassis and holder.
duneland is offline   Reply With Quote
Old 07-16-2007, 12:13 PM   #2398
CIMRI's Avatar
Hi Nigelnuggets,
I tried your setup this weekend. this was what need. It works great with no problem and I had a lot of steering
@ new3. I'll try your setup tomorow and let you now.
thnx
Old 07-16-2007, 12:25 PM   #2399
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
Hi Nigelnuggets,
thnx
Glad to be of service.
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 07-16-2007, 01:25 PM   #2400
gearhead_22's Avatar
Send a message via AIM to gearhead_22
I am putting together a serpent 07 960. I am having a problem with the servo arm hiting the chassis. I am using a jr 9000s with the rubber ends. It looks like the rubber ends are pushing the servo out too far.
gearhead_22 is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
