Old 09-20-2005, 07:42 AM   #226
M7H
M7H's Avatar
Originally Posted by Ferdi
Hi and thank for your reply!
The problem is that the 960 shocks are factory pre build.
So the lenght is fixed.
Thanks again
That's true, but still they can be unscrewed, or not?
Valt niet mee he, een autootje bouwen....
Serpent
M7H is offline   Reply With Quote
Old 09-20-2005, 12:36 PM   #227
Default S960 Shocks
The reference manual shows every part of the "pre-built" shock and it associated part number. I've just assumed that you could easily grip the shock shaft and unscrew the shock end from the shaft to ensure all shocks are equal. Just like the old shocks you had to build for yourself.
By the way, just finished my shocks, and I've got to give it to Serpent here too... Easiest, smoothest shocks in about 5 minutes ever. Might miss the adjustability though... :-)
Oh, and if your going to grip the shock shaft, to adjust the shock-end be VERY careful not to mar the shaft otherwise the scratchs can tear up those nice seals and the shock will start leaking. I use a pair of side/wire cutters and grip the shock shaft at the very bottom, right at the shock-end.. Don't know if it's the best method, but the one I used.
Darint is offline   Reply With Quote
Old 09-20-2005, 01:41 PM   #228
M7H
M7H's Avatar
Yes that is the best way, can be found in all previous manuals for the 950, vector......
Serpent
Old 09-26-2005, 07:11 PM   #229
Default Battery Pack for the 960
There is a 5-cell 900mAh pack for the 960 now available on Ebay. Does anyone know the correct part number for the battery holder for this kind of pack?
http://cgi.ebay.com/NEW-Serpent-960-...QQcmdZViewItem
Thanks.
going4#1 is offline   Reply With Quote
Old 09-26-2005, 11:48 PM   #230
border r/c's Avatar
Thanks.
the part nr is 903141
http://www.the-border.com
Europe's largest 1/8 scale 1/10 rc car warehouse.
3Racing-Ride-BRP-Team Orion-XRAY-HUDY-Serpent-Kyosho-Lrp-Speed Passion-MR33-JG-and many more
border r/c is offline   Reply With Quote
Old 09-28-2005, 06:44 AM   #231
sn4il's Avatar
Hi.
I just finished assembling my first 1/8th scale car - Serpent 960.
I'm hoping to get this car running this weekend.
Since it's my first 1/8th car i dont have any aligment tools for this scale.
What kind of aligment hardware works best for 960? What do You guys use??
max
sn4il is offline   Reply With Quote
Old 09-28-2005, 07:57 AM   #232
M7H
M7H's Avatar
Originally Posted by sn4il
Hi.
max
Check for the HUDY set-up boards......
http://www.the-border.nl/product.php...cat=108&page=4
Serpent
Old 09-29-2005, 07:24 PM   #233
Winner's Circle's Avatar
Default I am going to try LI-Poly batteries in my 960
I have purchased the li-poly battery, the charger and a switch harness/voltage regulator and I plan to try Li-poly batteries in my 960 this weekend. The pack I got is 1320 mah and it is lighter than the 600 mah pack that Serpent sells for the 950R.
I will post how these batteries work out after trying them out on Sunday.
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 09-29-2005, 08:00 PM   #234
whynot's Avatar
Trader Rating: 18 (100%+)
I was wondering if the front upper and lower arms on the 960 are the same as the 950-950r. thanks
mike
whynot is offline   Reply With Quote
Old 09-29-2005, 08:25 PM   #235
Default Front A-Arms
The 950R and the 960 share the same front lower and upper A-Arms. Not sure if it's the case for the 950, I believe the 950 has a different set.
Old 09-29-2005, 08:31 PM   #236
whynot's Avatar
Thank you very much
Old 09-30-2005, 12:56 AM   #237
SRAD's Avatar
Default 960 Battery
For those with 960's........I thought Serpent woke up and went back to the smaller sub c AA batteries instead of those crappy AAA cells. I plan on getting a 960 and I hope this is the case. Any info would be appreciated. Thanks
SRAD is offline   Reply With Quote
Old 09-30-2005, 05:13 AM   #238
Default Batteries
You can use either, the stock tray that comes with the kit is for the 2/3rd C's. Which is what I went to.
Old 09-30-2005, 06:04 AM   #239
aaron_buran's Avatar
The lower front a-arms are the same, the upper front a-arms are a bit longer due to the deeper offset of the pillow ball in the steering block, but you can still use your old ones up, there just not as strong as the new ones.
Horizon Hobby, JR Propo, Spektrum, Parma PSE, Faskolor, Tornado Racing Fuel, Calandra Racing Concepts, Murnan Modified Motors, Kyosho America
aaron_buran is offline   Reply With Quote
Old 09-30-2005, 07:28 AM   #240
C Verano's Avatar
I use a standard 1400mah 5 cell flat pack in mine.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
