Old 07-02-2007, 01:46 PM   #2356
Trader Rating: 16 (100%+)
Originally Posted by jeff1 View Post
I've already upgraded to Centax II. so it will no be a problem
Is that shaft you say?
http://www.serpent.com/product/902430/
thanks for support
Yes...thats the one. like M7H mentioned...the stock one might be too short..that I would not know. Back then, on the old Serpent website, there were several articles of someone installing the LC gearbox on VETEQ...and he did use the LC gearbox shaft as well with some modification.
Old 07-03-2007, 12:37 AM   #2357
avs
avs's Avatar
Originally Posted by J-MAN View Post
And get the front bulkheads shaved to were you can mount them 4mm lower than stock! Hope this helps!
so the lower flange is machined so that the whole bulkhead is lowered?
also, i measured a front bulkhead, and the upper and lower flanges are only 2mm and 3mm thick. could you mean 0.4mm?
avs is offline   Reply With Quote
Old 07-03-2007, 02:53 AM   #2358
M7H
M7H's Avatar
Hey M7H.. forgot to told you. The Centax II is working like a champ in my Vector.. it has larger bearing and holds up the stress very well.. I have not experienced thrust failure anymore. You and another guy helped me to install it on the Vector a few months ago
We are waiting your teaching how to fit this gearbox on Vector Have luck!
Your welcome.
In this link posted by you:
http://www.serpent.com/product/902410/
It is mentioned you should use a different shaft, it is because the 2nd gear from the LC gear box is thicker than the one from the vector. This way the hole in the shaft which holds the 3mm pin, is in the wrong location.....
It is probably this shaft you should order:
http://www.serpent.com/product/909634/
I am going to try to mount the LC gearbox in my Vector on an old 950 shaft.
M7H is offline   Reply With Quote
Old 07-03-2007, 10:02 AM   #2359
jeff1's Avatar
Originally Posted by M7H View Post
Your welcome.
Reading the description this shaft will be direct fit on the Vector, no mod required
I'll put on an order with these parts
Thank you Solara for the help. Really appreciate
M7H don't forget to tell us your experience installing the gearbox
jeff1 is offline   Reply With Quote
Old 07-03-2007, 10:11 AM   #2360
Its the same bulkhead that comes on the 07 car, i just know when you mount it the lowest its 4mm lower than the original car. And i was refering to the option chassis, when i was saying to remove the material around were the the front graphite plate mounts, i dont have a camera rite now so i cant post a pic. Hope this helps!
Jeremy Cupps
Sponsors are
Mugen Seiki, NovaRossi Engines, Enneti Tires, Byrons racing fuel, Airtronics, XceedRC, Mikes HobbyShop Porter Texas, Global Hobby Distributors, Avid Bearings, Paint by Smiley, and my wallet!
J-MAN is offline   Reply With Quote
Old 07-03-2007, 12:49 PM   #2361
Default Rony T530
Does anyone know if this bodyshell is EFRA legal [URL="http://http://www.redrc.net/?s=rony"]. Have tried the EFRA website but cant seem to find it there.
Thanks in advance.
Clubman is offline   Reply With Quote
Old 07-03-2007, 06:08 PM   #2362
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
Jeremy, the original bulkhead + new lowered suspension arm mounts only raise the front roll center 1mm more. So with the new mounts, the mounting position is only -1mm. Are you trimming the bulkhead more to receive an even lower setting?
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 07-03-2007, 08:28 PM   #2363
I'm a little confused here, the new lowered suspension arms raise the car's roll center. (to raise the front roll center you lower the top inner pivot point).
Which from the manual states a higher roll center (which is lowering the suspension arm).
- Decreases on-throttle steering
- increases car's responsiveness
- Increases weight transfer at front of car, but decreases grip
- Use in high-grip conditions to avoid traction rolling
- Better on trcks with quick direction changes (chicanes)
However, if you shim the suspension arm higher, you're lowering the front roll center which offers these effects.
- Increases on-throttle steering
- Decreases car's responsiveness
- Decreases weight transfer at front of car, but increases grip
- increases chassis roll
- better on smooth, high-traction tracks with long fast corners
So to get more steering wouldn't you raise the inner suspension pin?
Darint is offline   Reply With Quote
Old 07-03-2007, 08:48 PM   #2364
Essentially yes you would, but thats the OVERALL feeling.
As the pivot pin becomes lower and lower, it increases the steering responsiveness, which gives you that feeling of increased steering. Although it does take away more grip mid corner and corner exit, it makes for a much easier to drive car.
As the pivot pin increases in height, the response rate decreases, which would give it that initial push feeling.
These are my findings, hope it helps!
Old 07-04-2007, 02:51 AM   #2365
M7H
M7H's Avatar
Jeff, after taking the rear of the vector apart yesterday, I found out this "problem"
The Vector axle is this one:
http://www.serpent.com/product/9631
You can see that the drive/brake pulley is not secured with a grubscrew, but hold by a square "pin" on the axle...
http://www.serpent.com/product/9614
Also see this exploded view:
http://www.abc-rc-shop.nl/catalog/fl...nd_Part_I.html
So I think you also need to order this part with the new axle:
http://www.serpent.com/product/909248
Old 07-04-2007, 07:09 AM   #2366
ALG
Thanks in advance.
Hope this helps!!
ALG is offline   Reply With Quote
Old 07-04-2007, 11:56 AM   #2367
Hey Nigel, I believe I see your point, and it's likely why I compensate with heavier oil, which brings back responsiveness and initial turn-in.
Old 07-04-2007, 04:33 PM   #2368
Glad i could be of service my friend.
Old 07-06-2007, 04:46 PM   #2369
ALG
What type of LI-PO can I use on the 960? how much mah
http://http://rc-mushroom.com/produc...ducts_id=11291
Can I use that battery???
Thanks for your help
Old 07-06-2007, 09:45 PM   #2370
Manny Fresh's Avatar
Default I got one !
I finally brought me a 960 and can't wait to put it together.
Xray NT1
Blue Diamond RC
Manny Fresh is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
