Serpent 960....
#2251
Registered User
I think crystal park
#2252
hi guys
im eagerly awaiting delivery of my new serpent 960 07
ive ordered a few bodyshells and a pair of ko servos already got the new race + 21 engine and exhaust the only old part im using will be the sanwa 40mhz receiver
what id like to know from any-one who,s built this car is what else will i need to buy ,as id like to be ready when it arrives also what sort of time scale in hours will it take to build
i wished it was here now as here in the uk its a bank holiday weekend and pouring with rain
also any advice on a on off switch
any help gratefully received
regards
ray
regards
ray
#2253
Check out Serpent's website www.mytsn.com.. Search for the article from Glenn Cauley, he provides a very nice step by step (tips and tricks) build up for the 960, which is very detailed.
Take your time building, getting it "right" is more important than getting it "done".
#2254
This past weekend at the Texas biggie was my first race with the 960! the car is awsome, i think its the best car ive drove so far! and the Mega MF engines have insane horse power! Very happy with how the car drives, and the power! i cant wait to race it more! 1st race, with a win!
#2256
anybody knows if the front and back lower arm are intercheable.tnx
#2258
Congrats on this weekend. Shame with the rain.
DJ Apolaro
#2259
Originally Posted by garen
the rear lower arms are interchangeable, the front lowers are not
#2260
Originally Posted by nigelnuggets
Don't trip Steve, you're right!
To accomplish proper fitting of other manufacturers springs within the Centax II clutch system, a different flywheel nut must be used in place of the original!
A Kyosho or Mugen nut should do the trick!
Another thing, with the usage of lighter flyweights they produce less pressure on the plate which holds the shoe, which can cause premature wear of the clutch shoe.
A very successful clutch setup that we use here without having to use equipment from other manufacturers goes as follows:
Yellow (Brown) Clutch Shoe
T3 Flyweights with 3x3mm setscrews in the 2nd hole
SPP Centax plate
Serpent 1.8 spring (long)
Clutch Gap ~.5
Clutch Endplay ~.7
As far as the nut goes, adjust it according to the traction that is available at your local track!
Good luck!
SPP Centax plate
Clutch Gap ~.5
Clutch Endplay ~.7
Good luck!
#2261
DJ Apolaro
DJ Apolaro
#2262
whats the difference bet. the DSII and DSII+? i knw this is not engine thread sorry bout that.tnx.anybody?
#2263
low/ no traction on the rear
Hi guys,
need some advice on car setup on the rear...
i'm having problem with the rear traction, the car seems like wheel spin powering out of corner, sometime even when straight... is it possible due to too light rear??
I'm using the option ceramic, light WOS wheel shaft and 710 alu pilow ball on all 6....
rear toe 3.5, camber 3.5, shock oil and spring std. tire 67F/74R 35shore thanks
ck
ck
#2264
Originally Posted by ck960
Hi guys,
ck
ck
#2265
