Old 09-18-2005, 11:31 PM   #211
Default day at the track crystal park
Verano's car looked very good at Crystal Park today. Congrats on the win. I drove my 960 yesterday, me being a novice driver the car is easy to drive. I am glad I made the switch. You cant go wrong with the 960 it's a good car
Bryon
bestindebt is offline   Reply With Quote
Old 09-19-2005, 02:14 AM   #212
Ferdi's Avatar
Default Help wanted
Hi
I'm hard @ work with building my 960.
Sofar i have two questions relating the build of this great car.
1. How much rebound of the shocks is ok? The ones i have build rebound al the way back, is this ok?
2. There are four white (plastic) spacers deliverd in the package for building the oneway diff, on the drawing in step one of the cad drawing you can see that there is one spacer used on each side.
So now im in doubt if i have to use 2 or 4 spacers.
Can anybody help me out?
Thanks in advance,
With kindest regards.
Ferdi
Ferdi is offline   Reply With Quote
Old 09-19-2005, 02:40 AM   #213
M7H
M7H's Avatar
Thanks in advance,
Ferdi
It depends on your front track width....
Put in as many spacers as needed to give your front driveshafts as less "play" as needed......
a narrow front trackwidth, needs less or no spacers
a wide front trackwidth, needs more or all spacers.....
Be carefull, that they don't bind with steering......
Snap je me?, anders moet je me maar even een pm sturen
is dit je eerste 1/8 auto, want met de 950(R) en de Vector is het ook........
Serpent
M7H is offline   Reply With Quote
Old 09-19-2005, 10:45 AM   #214
C Verano's Avatar
Bryon
Thanks Bryon..
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 09-19-2005, 11:02 AM   #215
Mie3R's Avatar
After the IFMAR Championship, is there a possibility serpent will come out with 960R to overcome the minor problem with that car(if any)?
Mie3R is offline   Reply With Quote
Old 09-19-2005, 11:06 AM   #216
Default Tips on building the new RCC shocks from Serpent
Shocks: The proper way to fill the shock is: Fill the shock with oil until the third spire of the thread (inside thread in the alu shock). Insert the piston with the shaft all the way up. Screw in the piston assembly (1.5 turns) Slowly and progressively start pressing the piston until reach half travel (excess oil and air will leak). With the piston at half travel, screw all the way in the shock in order to seal it (by the way, we use a 9mm tool to tighten it) After this you need to check if there is no air. The shock is ok when after compressed, has a half travel rebound.
Paolo gave this tip and it works perfect.....more to come later for the 960...
Brian Berry is offline   Reply With Quote
Old 09-19-2005, 11:09 AM   #217
Buyer Beware
my boyfriend's 960 came in today...very beautiful car...now what engine shall he put in it?
i will be in charge of painting the body for it...any ideas?
HELLOkitty is offline   Reply With Quote
Old 09-19-2005, 11:27 PM   #218
Ferdi's Avatar
Thanks for all the tips you guys!
But now that i have the shocks finished they all have different lengths.
They should be, for front shocks 68mm and for rear shocks 73mm.
The shocks i have are: front shocks 67.40mm and 67.28mm. The rear shocks are 72.10mm and 71.81mm. Alle meassured fully extended.
Is anybody else having the same problem, is this a bad tollerance for the end build of the car?
Again thanks in advance.
with kindest regards.
Sincerely Ferdi
Old 09-20-2005, 12:22 AM   #219
R/C Driver's Avatar
Default best serpent 1/8 scale
I have been a Serpent owner since 1999 and have built and or drove them all. I must say that the 960 is the best serpent car I have ever owned. The car handled very well right out of the box using the standard set-up. I'm quite confident that I will be able to take my driving skills to the next level using the 960.
Chris
Congrat's on your victory and thanks for your help
Lewis
R/C Driver is offline   Reply With Quote
Old 09-20-2005, 01:27 AM   #220
MCRUZ's Avatar
Talking
Bryon
good job fast guy.
M32EVOX
MCRUZ is offline   Reply With Quote
Old 09-20-2005, 01:35 AM   #221
M7H
M7H's Avatar
Sincerely Ferdi
Ferdi, for more tips check this link......
http://www.mytsn.com/publ/publ.asp?pid=11388
Serpent
Old 09-20-2005, 06:02 AM   #222
Sincerely Ferdi
Ferdi,
This sounds like you may have screwed on the shocks ends too far and one may be more than the other. Bring the shock ends out (unscrew) slightly to make for proper length.
Old 09-20-2005, 06:13 AM   #223
Ferdi's Avatar
Hi and thank for your reply!
The problem is that the 960 shocks are factory pre build.
So the lenght is fixed.
Thanks again
Old 09-20-2005, 07:19 AM   #224
C Verano's Avatar
Chris
Lewis
Thanks Lewis...No problem on the help.
Old 09-20-2005, 07:21 AM   #225
C Verano's Avatar
Originally Posted by MCRUZ
good job fast guy.
Thanks Marc..I'll call you later to see what your plans are for the RD.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
