Serpent 960....
Old 04-20-2007, 06:51 PM
  #2161
Racer Z's Avatar
Originally Posted by captian
i will be there next weekend
Next week I will!! Captian has 1000 post good job man
Racer Z is offline
Old 04-22-2007, 02:01 PM
  #2162
Orfeous's Avatar
got a problem with those two bearing adapters for the rear inner bearings.
the spacer in the middle of the inner and outer bearing is blocking the way for the inner bearing to get pressed in if you understand? can i remove the spacer?
problem is that my bearing inner diameter is smaller than the original bearing.
what to do??
Orfeous is offline
Old 04-22-2007, 03:19 PM
  #2163
RC-ProSpeed's Avatar
Default What body???
Racer Z, Captain, or Serpent What bodys are you guys using.... I have to get a new one, I was using the Lola VDS from Serpent... would the Parma Audi would work kind of the same....
with the VDS looks like I wa having better steering compare to the Protoform.
Also can you tell me how tight do I need to setup the clutch spring???
Thaks in advance..
RC-ProSpeed is offline
Old 04-22-2007, 06:27 PM
  #2164
Winner's Circle's Avatar
Thaks in advance..
We did a head to head shoot-out between the Serpent SUS Central body, the R10, The R03, the whip and the dome a few weeks ago and everyone thought that the Serpent SUS body was best followed closely by the Parma R10. The whip and dome made the car looser and the Parma 03 did not have enough steering. I hope this help.
Winner's Circle is offline
Old 04-22-2007, 11:26 PM
  #2165
captian's Avatar
see you at 301 then!!!! ah man stop that
captian is offline
Old 04-22-2007, 11:32 PM
  #2166
captian's Avatar
Thaks in advance..
i am using the serpent usa body ..as for the clutch set if you at 301 this weekend i will help you with that
captian is offline
Old 04-22-2007, 11:41 PM
  #2167
captian's Avatar
what to do??
i think this should help you with that problem and these help with the stress on the one bearing and help 2 of them work together
http://www.serpent.com/product/903225/
captian is offline
Old 04-22-2007, 11:47 PM
  #2168
Thanks... I think the clutch is finally the last adjusment that I need to make.... now is time to save some $$$ FOR A POWERFULL engine....because at 301 you guys are fast on that straighway.
BTW what gearing you running at 301..I got the stock one 16/48 19/45....
Old 04-23-2007, 07:14 AM
  #2169
captian's Avatar
BTW what gearing you running at 301..I got the stock one 16/45 19/48....
you mean first 16/48 2nd 19/45 and gearing all depends on the engine and tire size .
captian is offline
Old 04-23-2007, 07:32 AM
  #2170
Ups..my bad...yes the 16/48 19/45
The engine is Sirio
Old 04-23-2007, 08:58 AM
  #2171
captian's Avatar
The engine is Sirio
i used 16/49 19/45 and 50
captian is offline
Old 04-23-2007, 12:12 PM
  #2172
Orfeous's Avatar
no, i solved the problem... i took the spacer out and replaced the standard shims to the smaller shims that was included in the bag with adapters :P but the wheelbearing adapters arent good..! there are some play when i try them so i went back to my other yellow ones no play att all
Orfeous is offline
Old 04-23-2007, 12:35 PM
  #2173
Orfeous's Avatar
what tension on the front belt is recommended i have the hardest now and with a new standard belt not the pro..
Orfeous is offline
Old 04-23-2007, 12:51 PM
  #2174
Default Thanks
Thank you for the info.
Old 04-23-2007, 01:33 PM
  #2175
Even on the tightest front belt setting my belt would stretch and become loose. A friend of mine made me this front belt tensioner. Now my front belt last about 2x as long as in the past.
