Old 04-18-2007, 10:42 AM   #2146
captian's Avatar
Originally Posted by nigelnuggets
Although it is a U-turn situation there are still the 3 stages of that corner, In my opinion, the front blue springs will make the car react faster, but it will decrease the steering as soon as the weight is dumped back on the rear end as he is on the throttle in mid corner and corner exit.
If it is a hairpin, what you want is to be able to brake and attack the apex right? So in some cases if the rear end is too planted it can take away that initial steering response he's looking for. Once traction is applied to one area of the car, you remove steering somewhere else. In this case it seems that his rear end settings are super planted and the front end feels like its setup to take away some steering other than the detached sway.
I think he has two options:
Reconnect that rear sway bar and play with its stiffness.
Lower the front shocks and leave the front sway bar on in its flattest position.
well i can see that in some cases but we did not ask him what the track was like and what shore tire he is running those are major factors
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 04-18-2007, 10:45 AM   #2147
captian's Avatar
Originally Posted by dbl
Just got my Serpent 960 '07 today from Kamikaze Toys and Hobbies!
Thanks Sam!
good luck and have fun with your new ride
Old 04-18-2007, 10:46 AM   #2148
GHETTOTEACHER's Avatar
I run red all the way around (track sprayed days). 45 shock oil, Red front, yellow rear on non treated days (practice sessions). Rear sway bar at 45 degrees. Front shock position at lowest point. set rear at 2.5, and front at 1.5 toe.
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
Old 04-18-2007, 10:52 AM   #2149
captian's Avatar
Originally Posted by CIMRI
Hi,
Thnx for answers. I dont need quick response . I tried the Blue springs and loose a lot of steering. This is not a Hairpin stituation. Acctually Im happy with my high speed steering. But at the U turns I loose a lot of time and I have to break very deeply for entering the corner.
I will try Lowering the front shock position and inclining rear schock position.
And last options are wos steering blocks. Do you guys tried the wos steering block is it worth.
what the ride height on your car and what the over hang in the front of the body
Old 04-18-2007, 11:15 AM   #2150
CIMRI's Avatar
Default steering
Hi Guys,
Im using
- 35 shore GRP tires all around. front 68mm, rear 74 mm.
- My ride high is front: 7mm, rear.7,5 mm
- my body over hang is 8 mm.
- I am using proline Lola body. At the moment I cant get the central body
Our LHS has not this body.
- The track is very clear and new. But the grip is not enough. We put every
time Cola on the track Actually the grip condition is . Medium.
between thnx for the many answers.
CIMRI is offline   Reply With Quote
Old 04-18-2007, 11:23 AM   #2151
RC-ProSpeed's Avatar
Default 950....
Thanks Captain, Serpent, ghettoteacher, racer Z for sharing some info...
Originally Posted by Racer Z
Sorry but I forgot that you were running the 950 or did you step up to the 960?
I will step up soon...Just need to save some more $$$
Currently I did try my 950 with the setup you told me (racer Z) and it did help a lot...
I'm just trying to see what other little changes I can make to be able to hit hard on the gas when I come out of the turns...right now is almost there, but still you can tell that the rear end is about to give up....and that makes me slow down on my times..(scare that the car turn sideways) So I just want to be with confidence that the rear end is not going to give up....
I'm running red springs front and yellow rear...
Shock positions for the rear is on the second hole staring from the bottom.
Any Ideas on what else I should try to adjust.
thank,
Guillermo
RC-ProSpeed is offline   Reply With Quote
Old 04-18-2007, 11:37 AM   #2152
captian's Avatar
Any Ideas on what else i should try to adjust.
thank,
Guillermo
any time
Old 04-18-2007, 01:48 PM   #2153
serpent's Avatar
Send a message via AIM to serpent
Hi Guys,
Im using
Try the Audi R10...kinda neutral..or even more steering the Kyosho Dome!!!
serpent is offline   Reply With Quote
Old 04-18-2007, 01:59 PM   #2154
serpent's Avatar
Talking
thank,
Guillermo
RC-ProSpeed If you're running at 301 Raceway try laying your shocks in the last hole from the bottom, ride height around 5.5 front 6.0 in the rear.....I've found that using 35 shores all around I use 1.0mm of tire wear for a 5min qual., since the sweeper start and finish at 301 is a right turn I use more camber "side-to-side grip" on the pipe side of the car "no more than 0.5mm...but I may try 1.0+!!
Dem Snakes!! Dem Snakes!!!
Old 04-18-2007, 09:17 PM   #2155
Racer Z's Avatar
thank,
Guillermo
On power coming out of the corner: Try more rear toe less dampning,less rear sway bar angle in the rear and less droop in the front like 0 instead of 1.
RC AMERICA, HUDY, XRAY, Nexus Racing, Desoto Racing, 301 Raceway(RIP). XRAY T4/NT1 coming for that #1 spot!! AKA-Melvin Aulston
Racer Z is offline   Reply With Quote
Old 04-19-2007, 05:09 PM   #2156
captian's Avatar
any serpent guys running at vegas
Old 04-19-2007, 05:26 PM   #2157
Default Thanks
Thanks for all the tips....
Are you guys going to practice on Saturday?
Old 04-19-2007, 05:38 PM   #2158
captian's Avatar
i will be there next weekend
Old 04-20-2007, 06:36 AM   #2159
Default Lostallo Setup 1/8
Anyone got any 960 setup's for this track in Switzerland.http://www.mrtm.com/home2007.htm . Searched the web but cant find anything.
Thanks in advance.
CM
Clubman is offline   Reply With Quote
Old 04-20-2007, 01:09 PM   #2160
captian's Avatar
Thanks in advance.
CM
check on the serpent site there mite be one there you can use
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
