Old 09-14-2005, 12:56 PM   #196
duneland's Avatar
Sorry Howard, I am told the Picco wheels are propriatary (only fits Picco).
Serpent, PRP XR8, GS Sonic use same wheel.
Kyosho, Delta, Mugen share same wheel (off-set).
Don't know about HPI.
duneland is offline   Reply With Quote
Old 09-14-2005, 12:59 PM   #197
Buyer Beware
the 960 is on its way here and into the hands of my boyfriend....i hope he is happy.
i also heard that this car is very nice....
HELLOkitty is offline   Reply With Quote
Old 09-14-2005, 02:59 PM   #198
Trader Rating: 16 (100%+)
RON...thanks, that answered my question..........GOOD LUCK this weekend at Toledo @ MWS #5, I will sit out this one......but will get back with you guys at Hamilton for the finale....Good luck.
Old 09-14-2005, 10:35 PM   #199
Thumbs up Initial Thoughts - Building the 960
I received my 960 this afternoon, and excitedly begin putting it together. This is the 5th or 6th Serpent kit I've built, 705, 835, 950R and now the 960. Of all the kits, I'd say it's simply the best build. I spend a lot of time ensuring each A-arm both top and bottom fit correctly and are smooth enough to fall by their own weight (the plastic arms fall by gravity even without the hubs, pillowballs and bearings etc). Usually, I spend quite a bit of time ensuring this smooth movement of the arms. The new Serpent 960 went together without the need of my normal heat gun or the occasional reamer to get the fit I needed... It was simply follow the directions and the A-Arms fall on their own... So far, the fit finish and build are simply on a whole new level. I haven't driven the car (yet), but I can say from the beginning of the build, this car is definetly taken a step in the right direction.
www.tsrcar.com
Darint is offline   Reply With Quote
Old 09-14-2005, 11:33 PM   #200
C Verano's Avatar
www.tsrcar.com
I experienced the same thing while building my kit. Everything fit really well.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 09-15-2005, 12:00 AM   #201
Thumbs up 960
i got the 960 saturday the car went together easy no problems it went together in about 6-8 hours . it is the nicest i car i put together. the parts fit nice and the suspenision movement was free
i was very impresed when i saw the car on the track it carried a lot of corner speed an rotated very well i am glad i made the switch
bryon
bestindebt is offline   Reply With Quote
Old 09-15-2005, 06:57 AM   #202
Mie3R's Avatar
Originally Posted by going4#1
Not really. I believe it's more a culture of ideas difference. Mugen and Kyosho don't bother explaining what everthing does. They just tell you how to set up the car so it's drives in a stable configuration. Serpent has been around a long time, near the beginning of RC pro racing. Everything is geared to understanding your race car and what each setting does but not holding your hand. The idea is, you figure out what to do and set the car up to do that. This is either very good (because you need to understand how settings effect the car) or an annoying pain in the ass (there are only so many hours on a Saturday you wish to waste setting up as opposed to racing). From the 710/950 the basic setting is fairly stable. As for the 960, it seems the basic setup makes the car quite quick. Fewer adjustments may be needed to get it optimal.
Rob
thanx rob
Mie3R is offline   Reply With Quote
Old 09-15-2005, 07:20 AM   #203
aaron_buran's Avatar
I agree this is the best kit yet, a couple of finer points that you should keep an eye on during assembly.
1.) With JR Servo's and grommets, you need to flip the steering mount over to get the steering linkage in the proper geometry for JR servo's
2.) With the throtle servo in the upright position you can mount the JR servo under the radio tray, to get it lower. Mount the throtle linkage to the inside of the servo, otherwise it may rub the tank. This will work with KO as well.
3.) If you mount the larger battery pack nice and clean, by taking off all the excess heat shrink, you can lower the tank a couple mm, by substituting washers instead of the provided shims. You will also get better clearance when the carb slide is fully extened.
4.) When you run the rear of the car wide 262-263mm, the rear dog bone lash is a bit much. Cut the some of the other dog bone spacers provided or use some fuel tubing to reduce the amount of play.
5.) If you run the aluminum x-brace under the radio tray, the side brace on the side belt tensioner side doesn't mate up perfectly with the rear bulkhead, a few clutch shims between the rear bolt on the side plate and left rear bulkhead fixed this, so you don't tweak the side plate and tensioner.
If you didn't do any of these things, it's okay they are not big issues, just little things to make a great car even better.
I'll continue to post more, if you guys are interested.
The car was great the first time out at Toledo last weekend, it should be awesome for the Midwest Series race this weekend.
Horizon Hobby, JR Propo, Spektrum, Parma PSE, Faskolor, Tornado Racing Fuel, Calandra Racing Concepts, Murnan Modified Motors, Kyosho America
aaron_buran is offline   Reply With Quote
Old 09-15-2005, 07:35 AM   #204
C Verano's Avatar
That's good info Aaron..Please continue to post your building tips.
Old 09-15-2005, 01:57 PM   #205
C Verano's Avatar
bryon
Bring the car to CP on Saturday so you can shake it down. I'll help you get it set up so you're comfortable driving it.
Old 09-15-2005, 03:53 PM   #206
R/C Driver's Avatar
Go Serpent
R/C Driver is offline   Reply With Quote
Old 09-15-2005, 06:59 PM   #207
whynot's Avatar
Trader Rating: 18 (100%+)
Thank you very much arron.If you read this can you send me your toledo setup.And do you put the fuel tubing into the same place that the spacer plug goes or do you put it in the other side. thanks [email protected]
mike
whynot is offline   Reply With Quote
Old 09-15-2005, 07:22 PM   #208
Default Hobby gets cheaper.
I would not hold this back from you. On the ever growing expenses in rc land.
Great combo price for 1:8th tires
If you are outside the european union:
8 tires 2 sets front + 2 sets rear for 1:8 cars serpent,mugen,kyosho for 56 dollars.
Bigger quantitys get even better prices.
look at the combo deals.
nitrodudes is offline   Reply With Quote
Old 09-17-2005, 12:48 AM   #209
The OX's Avatar
Default Is a conversion possible?
Gday,
I havent had a good look at the 960, but is a conversion kit goig to be available for the 950r?
Cheers
The OX
The OX is offline   Reply With Quote
Old 09-18-2005, 05:41 PM   #210
ogreasurada's Avatar
I dont think there will be a conversion cuz the 960 is almost a complete new blueprint from the 950, unlike the evolva which only recieved minor upgrades.
ogreasurada is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
