Old 03-19-2007, 08:20 AM   #2056
Racer Z's Avatar
Originally Posted by SRAD
Check the rear camber.....looks like you have positive camber!!! Looks like you also have ALOT of rear toe!!
I have to agree with SRAD. Can you take a picture from the top looking straight down on the car (top view)
RC AMERICA, HUDY, XRAY, Nexus Racing, Desoto Racing, 301 Raceway(RIP). XRAY T4/NT1 coming for that #1 spot!! AKA-Melvin Aulston
Racer Z is offline   Reply With Quote
Old 03-19-2007, 12:43 PM   #2057
Greg M's Avatar
I need to get it back on a set up system, but it was initially set up with 3 degrees of toe in and the tyres wear even, so no problem with camber, the car was probably just sitting weird when I took the pic. I'll take a few more pics tonight as the camera I borrowed has gone flat.
Greg M is offline   Reply With Quote
Old 03-19-2007, 04:24 PM   #2058
avs
avs's Avatar
interesting, with that much toe-in i would expect noticable coning on the tires, unless there was very little camber.
not that i have gotten everything perfect on my 960 yet, but so far it seems to want more camber and less toe-in. (like 3 degrees camber to 2 degrees toein) and resulting with 1degree or so of coning on the tires
avs is offline   Reply With Quote
Old 03-19-2007, 04:35 PM   #2059
Greg M's Avatar
I'll be borrowing a set up system before next race day and will reduce the toe. I've just always run that much toe, as its a pretty tight track.
Old 03-20-2007, 02:54 AM   #2060
Greg M's Avatar
Heres another pic from top.
Old 03-20-2007, 05:06 AM   #2061
I'd recheck you rear track width for the 262mm from the outside of the center of each rear tire. Just lay it on a ruler with mm's..
If that's good, I would start by removing the tires, disconnecting the sway bar, remove the shocks and removing the body mount. This will free up both sides of the rear independently. Lift up each side and see where it "falls", if they fall equally without drag (and downstops are equal) then start reconnecting each of the above one at a time and retest, to determine where the problem is..
Hope it helps good luck
www.RCAmerica.com - XRAY - HUDY - Max - JACO - KO PROPO
Darint is offline   Reply With Quote
Old 03-20-2007, 08:47 AM   #2062
jeff1's Avatar
Hello. Can someone help me? I need the #part number of these two centax bearing and width too
This is how I found on the manual (an user posted here and its not complete)
Inner Bearing U45 5X13m
Inner Bearing 4 5x10mm
jeff1 is offline   Reply With Quote
Old 03-20-2007, 10:10 AM   #2063
The 5x13mm bearing (big) is #1340 and #1380 if you would like the Ceramic one.
The 5x10mm bearing (small) is #1315.
The spacer (5x7mm) that goes in between those two bearings is #909514.
Hope this helps.
Kendall is offline   Reply With Quote
Old 03-20-2007, 10:29 AM   #2064
jeff1's Avatar
Hope this helps.
It helps a lot
Thank you
I found 1315 in mushroom.com however they doesn't have 1340... if you would know the width I can buy a generic mushroom bearing
Old 03-20-2007, 03:52 PM   #2065
Gergely's Avatar
Hi Greg!
You should check the upper pivot ball in the rear upper arm. I had the same problem. It only turns out when you setup the rear end of the car. It's a bit too easy to install the rear upper pivot ball athwart. And since it is the same part left and right it just getting worse because they lean into opposite direction.
Hope this helps for you also.
Gergely is offline   Reply With Quote
Old 03-20-2007, 03:56 PM   #2066
Greg M's Avatar
Originally Posted by Gergely
Hi Greg!
Thanks, I'll check that out tonight.
Old 03-20-2007, 04:09 PM   #2067
Orfeous's Avatar
Send a message via ICQ to Orfeous Send a message via AIM to Orfeous Send a message via MSN to Orfeous Send a message via Yahoo to Orfeous
those new plastic bushings.. for pivot balls do they lighten the car? and how much? i mean.. you change from steel to plastic.
Orfeous is offline   Reply With Quote
Old 03-20-2007, 07:22 PM   #2068
SMcpot's Avatar
Trader Rating: 22 (100%+)
If you mean the plastic pivot ball nuts, I just ordered some but can't imagine they'd affect the total weight of the car much. If anything, they reduce unsprung weight and hopefully do away with the slop the stock two-piece arrangement has.
SMcpot is offline   Reply With Quote
Old 03-20-2007, 09:11 PM   #2069
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
It helps a lot
Thank you
you can find all your clutch parts and necessities at Kamikaze toys and Hobbies. give them a call at 714-997-8697
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 03-21-2007, 04:00 PM   #2070
Send a message via MSN to PMSorber
Am I wrong or is your rear stabby link at the right side connected to the inner hole compaired to the left side (outer)?
Also check the length of these rods!
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
