Old 02-17-2007, 03:56 AM   #1951
Orfeous's Avatar
Send a message via ICQ to Orfeous Send a message via AIM to Orfeous Send a message via MSN to Orfeous Send a message via Yahoo to Orfeous
have you seen all those new options that are available??
titan rods for shocks.. for example..
Orfeous is offline   Reply With Quote
Old 02-21-2007, 11:58 AM   #1952
RedRC's Avatar
Hi Guys,
Heres a picture of the new for 2007 Serpent 960 '07. You can find some more pictures and information here.
RedRC is offline   Reply With Quote
Old 02-21-2007, 02:33 PM   #1953
hey guys, just wondering wot ride height u guys run and on what tyre size?
currently on the front im on 68mm tyres +1mm downstop and cant seem to get ride height lower then 10mm
bigboss is offline   Reply With Quote
Old 02-21-2007, 10:54 PM   #1954
Racer Z's Avatar
Im running 68mm in the front and 74mm in the rear. Im running 7mm in the front and 7.5mm in the rear for ride height. What springs are you running?
RC AMERICA, HUDY, XRAY, Nexus Racing, Desoto Racing, 301 Raceway(RIP). XRAY T4/NT1 coming for that #1 spot!! AKA-Melvin Aulston
Racer Z is offline   Reply With Quote
Old 02-22-2007, 01:23 AM   #1955
yup 68mm in front 74mm inn back, everything on car is stock, just cant seem to figure out what the problem is!
Old 02-22-2007, 05:58 AM   #1956
Winner's Circle's Avatar
If the problem is too much ride height on the front it could be caused by front anti roll bar being set too deep in the cup. This will cause the front suspension to not move all the up and down due the the fact that the ball is bottoming out in the cup and limiting suspension travel.
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 02-22-2007, 06:49 AM   #1957
M7H
M7H's Avatar
Or the up- and downstop settings are wrong.....
Serpent
M7H is offline   Reply With Quote
Old 02-22-2007, 07:23 AM   #1958
Racer Z's Avatar
Where are you measuring your 1mm of droop at? Are you doing it on the arm, knucle or lower edge of pivot ball. It sounds like you may have set the downstop incorrectly.
Old 02-22-2007, 09:25 AM   #1959
here is how i measure downstop
Old 02-22-2007, 10:43 AM   #1960
http://www.serpent.com/product/903004/
Luke W is offline   Reply With Quote
Old 02-22-2007, 11:43 AM   #1961
flack's Avatar
Originally Posted by Luke W
I may be missing something but from what I read and saw...the only thing different from the FD model is the black chassis.
Doug
flack is offline   Reply With Quote
Old 02-22-2007, 01:40 PM   #1962
Info on Serpent Nine Sixty '07
Hi guys, just a brief comment on the 07 version of the 960. This car is a natural evolution of our original 960 and FD version featuring some performance enhancing and durability upgrades.
Nine Sixty '07 includes:
- Servo saver system with adjustable Ackerman, 4 positions;
very easy to use system with nylon inserts
- CV-front drive shafts: hardened steel and precision-made
CV-axles
- Harder nylon parts throughout the whole car to increase
chassis-stiffness and make them more wear -and breakage resistant
- Modified left rear bearing block, improved stiffness and
improved 2-speed shaft support
- Black anodized chassis plate for new looks, with extra
CS-hole to mount the rear left bearing block (LCG is an optional)
- Carbon fiber side plate with coated alu insert with High
Speed 6x13 bearing, for improved 2-speed shaft support and chassis-stiffness
- Nylon adjusting nuts to set the 8.5mm pivot balls front and
rear; these replace the alu versions and the small pivot cup used before.
- Machined aluminium upper suspension-brackets with nylon
roll-center inserts 1mm lower than previous version
- Fuel-tank with bronze filter and o-ring sealed AFL-cap
- As extra: Wide off-set steering blocks, for tracks where
even more steering is need
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 02-22-2007, 01:48 PM   #1963
Suspended
CV-axles
just wondering,whats the price of this kit?
MERCCER4LIFE is offline   Reply With Quote
Old 02-22-2007, 01:56 PM   #1964
Thanks for the detailed info Paolo.
Kendall is offline   Reply With Quote
Old 02-22-2007, 03:49 PM   #1965
i check the springs, and found out the blue front blue springs are 1mm longer then the back yellows,
now with yellow front and backs, i have lowered my front to 9mm ride height, just aint sure how to get it another 2mm lower as it saids in the set up
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
