Old 01-28-2007, 08:28 PM   #1906
Originally Posted by Winner's Circle
Paolo
I just shimmed my front wheels out and went to the outside hole for the pin that goes through the quick change. Will this be basically the same thing as going to the WOS steering blocks?
Lee: No, it's not the same. The std steering block are zero deg, wich means that the position of the lower and upper pivot ball is the same. In the WOS, the upper pivot ball is moved to the inside compared to the lower one. You have to mount this upside down (left to rigth and viceversa).
The WOS axles have a total different effect. I use the pin in the Std hole.
Taner: to achieve more steering you just need the steering block. The axle are nice cause are lighter thanthe stock ones, so lees weigth on the rotating mass and suspended mass in the suspension
Paolo
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 01-29-2007, 11:59 AM   #1907
Taner's Avatar
Default wos
Hi Paolo,
thnx for answer. I will try the wos steeringblock as you say.
I have the serpent universal axels ! they are light enough. Thats way ,I thing the wos axels are not "must" for me.
Taner
Taner is offline   Reply With Quote
Old 01-29-2007, 12:45 PM   #1908
Orfeous's Avatar
Send a message via ICQ to Orfeous Send a message via AIM to Orfeous Send a message via MSN to Orfeous Send a message via Yahoo to Orfeous
Hi guys!
havent got any answer for my questions.
please answer..
What gearshaft are you using? titan? spp? standard?
then i wonder how you have mounted your reciever.. and i would like to see pictures. So i get an idea how to do. The problem for me is my friend that i bought the 960 from has brake the screwhole on the radioplate there the reciever is supposed to be mounted. maybe i can glue with epoxy or something and make a little hole in it? i dont feel to buy a new one for nearly 100 Euro
Orfeous is offline   Reply With Quote
Old 01-29-2007, 02:32 PM   #1909
Taner's Avatar
Hi Orfeous,
I had the Jp Titan and the standart shaft. But I broke both shafts. I ordered the spp shaft today. And hope it is stiffer than jp titanium and standart shaft.
Old 01-29-2007, 05:27 PM   #1910
Default 2-speed shaft
Hi guys,
for 960 i only have the SPP mid shaft, is there a SPP 2-speed shaft?? what part no??
thanks
ck
ck960 is offline   Reply With Quote
Old 01-30-2007, 02:13 AM   #1911
Taner's Avatar
Default shaft
Ck,
http://www.the-border.nl/product.php...cat=260&page=2
Old 01-30-2007, 06:12 AM   #1912
Orfeous's Avatar
Ok, i am gonna order spp shaft for me also but it isnt available yet from hongkong :P restordered.
What about the reciever mounting?
Old 02-01-2007, 08:17 AM   #1913
Default 960 2 speed shaft pro/spp
Hi Taner,
I cant find this part# at serpent website... is it from other manufacturer??
And how much lighter it is then the std shaft Thanks...
regards,
ck
Old 02-01-2007, 08:31 AM   #1914
Taner's Avatar
Default shaft
Hi,
It is serpent spp produktion. But it is on serpent website really not to find
But Border have this shaft. My order is on the way....(ordered from Border)
Old 02-01-2007, 08:33 AM   #1915
rpoage's Avatar
The item is Very New and is not shown on Serpent site yet. The part # is SER 903208. Serpent USA doesn't have it as of yesterday but we have it on order. I would expect it to be available in the US soon.
Ashford Hobby SER 903208
Ashford Hobby
Real time inventory for the things you need.
rpoage is offline   Reply With Quote
Old 02-01-2007, 09:41 AM   #1916
Orfeous's Avatar
allready got it in sweden..
its really light.. lighter than standard. beacuse of the new spp have been hollowed. it can be done with the standard steel shaft too. to lighten it up some.
its gonna be fun to try those in summer
Old 02-01-2007, 09:58 AM   #1917
flack's Avatar
Hi Guys,
Has anyone the overdrive ratio for 960s? Or do u guys now any links?
thnx
Taner
Originally Posted by Doug M
You can use the same chart as the 950R. Below is the link for downloads.
http://www.mytsn.com/products/downlds.asp?prid=3277
I am a little knew to the 960 but know the front and rear transmissions aren't the same and would require different tire sizes. I have not seen in the manual, reference guide or setup guide any mention of this. The link above does not appear to work with the new site redesign.
Isn't this information a little important when running these cars?? Where do you go to get the necessary charts or information?? Any help would be appreciated.
Doug
flack is offline   Reply With Quote
Old 02-01-2007, 10:35 AM   #1918
Orfeous's Avatar
Doug
Try this gear calculator for serpent 720 and 960
http://umea3.mine.nu/~anton/filer/serpent/
Old 02-01-2007, 11:35 AM   #1919
Default chasis 2007
I have seen that there is a 2007 chassis version, does anyone seen it is there a big different? when is going to be available?
Roedor is offline   Reply With Quote
Old 02-01-2007, 02:51 PM   #1920
Taner's Avatar
Default 2007 kit
I thing, this is the kit with all upgrades. new hard plastic parts, T2 side stiffner, 3. bearing, AFL tang cap etc... Like Fabia D. edition but w.o the alu options.
And the chassie have the 3. screw hole for the new rear left bearing block for stiffer use.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
